Question about Nokia N97 Cell Phone
How can i put my phone on vibrate pressing the # key
  • 232 Answers
By default, the silent profile has the vibration off. Go to settings-->Porfiles-->Choose Silent-->options-->Personalise-->set the vibrate alert On.If my solution solved your issue ,vote for me.
Posted on Oct 02, 2009
I don't want my phone to be in silent mode!!! Help!
To turn off the ringtone:
Press and hold the Power key on the top of the phone, then tap Silent mode.
Press and hold the down the Volume key until the volume bar is empty and the Ringer volume icon has a x next to it.
To set the vibrating alert:
1.From the Home screen, find and tap Settings.
2.Tap Sound & display.
3.Mark the Phone vibrate checkbox.
Tip: When in silent mode, press the Volume key up once to activate the phone vibrate mode.
Do the opposite to turn it back on.
Jul 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Don't know how to put the phone just on vibrate only
YOU CAN CHANGE IT FROM PROFILE OR JUST CHECK VIBRATE BUTTON ON #, IF U CAN'T FIND THE SIGN ON IT, PRESS # KEY FOR 3 TO 5 SEC, IT WILL CHANGE THE PROFILE TO VIBRATE
Jan 30, 2011 | Cell Phones
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
How do I put my lg neon on silent mode without going through the menu and changing the ringtone? I can't find it anywhere
i figured out how. on the volume buttons (on the side) you just keep pressing the down button even after it says vibrate., if you press it enough (consecutively) it will say silent all
hope that helped
Jan 03, 2010 | LG Neon GT365 Cell Phone
I want the keytone to be silent - how do I set it to silent?
You have to do the following:
Sound Profile
You can customize various sound profiles for your phone by
changing the sound settings.
1. In Idle mode, press the Menu soft key and select Settings
➔ Sound Profile.
2. Highlight one of the following sound profiles:
• Normal
• Silent
• Driving
• Outdoor
3. Press the Edit soft key to access the sound settings.
4. Press the Change soft key to change the "phone" option.
• To move between the various tabs, use the Left and Right Navigation
keys.
• To highlight individual options, use the Up and Down Navigation keys.
• To change the setting for a highlighted option, press Change ( ).
There you have these options:
– Keypad Tone: allows you to choose between Beep, Xylophone, and
Mute (no tone) for keystrokes on the phone.
– Power On Type: allows you to select the way in which the selected alert
is played when the phone is powered on.
• Melody: the phone sounds the selected melody.
• Vibration: the phone vibrates.
• Vibration & Melody: the phone vibrates and also plays the
melody.
• Mute: the phone neither vibrates nor plays a ringtone. The only
indication of a message is an alert on the display.
5. Press the Save soft key when you are finished.
Normal Profile
To access the available options for this sound profile, press the
Edit soft key.
keys.
• To save your changes, press the Save soft key.
This should do it.
If you still have some problems please download following manual and go to page 69 where you find all related info.
Propel Manual
.pdf
Hope it helped.
Nov 20, 2009 | Samsung Propel A767 Cell Phone
Can you turn the key pad off on the Pantech Slate C530 without putting my phone on silent or vibrate
In the menu, to to "Settings", then "Sounds & Alerts". Put the select bar over "Normal" (if that's the setting you use it on), pressing the "Options" button and selecting "Customize". Find "Keytone Type" and press the left or right arrow buttons to select "Off". Then select "Save". You can do the same for "Vibrate and Ring".
Apr 29, 2009 | Pantech Slate Cell Phone
How do you put the LG VOYAGER VX10000 on vibrate
the other solution is not what i think they are asking.
there are many ways to put the phone on vibrate:
1. closed: press the phone icon and hold the # sign.
2. open: hold down the Z key from the main screen.
3. open or closed: press the down volume key on the left side of the phone until it says vibrate.
Feb 24, 2009 | LG VOYAGER VX10000 Cellular Phone
Manner Mode
press and hold the star key it should say manner mode activated. to get it off press and hold star key again
Sep 19, 2007 | LG VX3400 Cellular Phone
No Vibrate
Go to menu, tools, sound settings, call sounds, then click on call vibrate. click on. click ok.
Sep 08, 2007 | LG VX8300 Cellular Phone
Nokia N97  Cell Phone Logo
357 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
