Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
No idicator lights door wont close - Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
  • 21 Answers
Door may have been pulled off its hinges, the d/w doors electric is connected at the bottom of the door and when it was pulled, there is the possibility that a short occurred.
The door of the bosch will pull straight up, carefully remove the door and then carefully place door back onto the hinges and making sure the door is seated properly. The door should close. The hope is that once the door closes, the sensors to the door should hopefully work, properly.
Try these before the more costly options which is either a new door or the call of a service technician.
Posted on Oct 15, 2009
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
Oven light on display says door and now wont heat
The oven will not turn on the heat because it thinks the door is still open. It thinks the door is open because it has a sensor that gets pressed by the door when it closes (look around edges of oven that get covered when door closes) this sensor is wet, dirty or broken so when you close the door the sensor still says its open. Did you clean around the door with a wet cleaning fluid?
Dec 20, 2013 | Whirlpool GBS307PRS Stainless Steel...
Daytime running lights, wont come on, idicator light flashes, changed bulbs and drl module, still wont wrk
you should have a fuse under the hood for daylight running lights in the black box
Feb 28, 2010 | 2005 Pontiac Sunfire
Jaguar S-type --- drivers door open idicator will not shut off
the switch should be by the bottom of the door or near the hinge it gets depressed when the door is closed and it pops out when the door is opened some times it gets dirty and wont function correctly fairly easy to change on most cars also same location on most cars.
Dec 01, 2009 | Jaguar S-Type Cars & Trucks
Blinkers are intermittent and now there is a light idication that the door(s) is ajar. Also interior lights stay on all the time
chk the engine to body ground strap. Located ttop rear of engine and screw to firewall. make sure it is clean and secure.
Oct 28, 2009 | 2000 Dodge Caravan
I have a Craftsman 1/2 HP model #13953975SRT1.
It is normal for it to blink randomly. If you watch it while you press your remote you will see what it looks like when it is receiving a properly coded signal.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Interior lights wont shut off?
sounds like door switch is bad
Nov 11, 2008 | 1998 Ford Windstar
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
190 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
