Question about Intel D915GAV Motherboard
I HAVE AN INTEL 915GAV MOTHERBOARD,IT USED TO SUPPORT RAM - 400Mhz BUT NOW IT IS NOT WORKING ON 400Mhz & REQUIRES 333Mhz?
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
aaa7
Posted on Oct 10, 2009
SOURCE:
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
I have a Biostar Motherboard K8M800-M7A and i just recently bought a kingston ram memory 1GB 400mhz KVR400X64C3A. Everywhere i look for on the internet says they are compatible but i dont get them to work....
You are correct, this motherboard can use either 333mhz DDR (PC2700) or 400mhz DDR (3200) chips.
You may have a bad chip. Also make sure you are not mixing this chip with another of another speed. Its not good practise to mix 333mhz and 400mhz though some motherboards will still work like that.
Your best bet for compatibility is crucial DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64 •
Personally I have had bad luck with kingston ram myself.
Chris
May 19, 2011 | Computers & Internet
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
I have 4 slots of ram in intel d915glvg how much ram can be increased in each slot
Good Day.
Your motherboard can accommodate up to 4GB of memory. That means you can have 4pcs of 1GB DDR SDRAM 400mhz or 333mhz memory modules to maximize your memory. Just be sure to have the same speed (400mhz or 333mhz).
Just let me know if you need some more help.
Good luck,
Tedmac
Sep 25, 2010 | Intel D915GLVG Motherboard
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
Does D845GVSR supports DDR 400 MHz RAM?
unfortunetly your motherboard supports only 200, 266, and 333 MHZ
Nov 29, 2008 | Intel D845GVSR Motherboard
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Can i use DDR2 RAM in intel 865GBF motherboard?
NO ! you can only use DDR 1 ram (266Mhz,333Mhz,400Mhz) speeds only
Mar 30, 2008 | Intel D865GBF Motherboard
RAM
As long as the memory voltage is correct it will run the memory at 333MHz. Check for a bios upgrade for the D845EPI.
Your board's update link.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1066&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Enjoy!
please vote...
Feb 18, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D915GAV Motherboard Logo
425 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
