Question about KitchenAid Refrigerators
The top opening of the ice exit is frosting over . the layer of ice is not even an inch thick and I can just chip it out but then it ices over again so the ice wont come out.
  • KitchenAid Master
  • 4,654 Answers
A leaking water control valve for the ice maker side will cause this. Unplug the wires to that side coil and see if the problem continues. If yes the water control valve may be the problem. Also sometimes the heating element under the ice maker stays on too long and will cause the same symptoms, Send the model number and I will assist you in your repair, Thanks, Sea Breeze
Sears model numbers look like this for example 213.054689
Posted on Oct 02, 2009
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
I have a lg fridge/freezer model grb218juda. The freezer is at the bottom and a thick layer of ice keeps forming which i have to scrape away monthly. the seal is not worn and this appliance is 3 years old
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 18, 2010 | Refrigerators
Everything in the freeze has a thick layer of ice
Typically, this is an indication that the seal on the door needs to be either cleaner or replaced. begin by cleaning it thoroughly, also clean the frame of the door. Then defrost the ice using a blow dryer and dry it. Then over the next few days you will know if it is the seal if the ice forms again.
Dec 05, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
May 26, 2009 | U-Line Icemaker
Freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Apr 23, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
