Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I can not get it to work on my laptop - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Posted on Oct 02, 2009
    Sergeant:
    Champion:
  • 208 Answers
Try using another USB port. Does it work on another computer?
Hdd 2tb only showing in device & printers
Sounds like you require new drivers for the USB sockets. Only use Acer drivers, Microsoft are not trusted to work without issue.
Acer Explore Beyond Limits
Aug 30, 2016 | Acer Aspire V5-571P-6835 15.6" Touch...
Blue screen occuring and the laptop restarts
maybe the problem of your laptop was the memory ram that was built in... or the hard drive i think...
Aug 11, 2012 | Dell Computers & Internet
I have hp laptop #hp g60_120us . around 2 years. lastnight. i hibernate it .went to do something, the laptop not working anymore when i press on. the screen showing lot of red retangle sqaure from top...
- Shut down the laptop by pressing down the power button. - Remove the power input to your laptop. - Remove the battery and put it back after about 2-3 mins
Please report your observation
May 18, 2010 | HP G60-120US Laptop
I dont know how to work my built in mi web camera on windows live messenger
If your webcam is working then check it is configured to work in stand alone mode, you need to switch to Remote mode to other to work with any live messsenger.
Dec 25, 2009 | MSI M670 Notebook
Speaker randomly works
Please check the link: http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Hope it helps.
Oct 25, 2009 | Dell Inspiron 1525 Laptop
The laptop does not charge or work at all on AC. Before it quit working, it was not accepting a charge. my son said the plug in at the jack seemed very hot before the charger seemed to stop working...
You can easily test this by removing the battery from the laptop, plugging it to the wall & see if it will work on or not. If it works, then the problem lies within the battery. If it did not work, the problem might be in the adapter or the laptop itself. Try using another adapter which is known to be working fine & see if the laptop will work. Beware that the adapter must be of the same type used by your laptop.
You can also try your adapter on another laptop of the same type to see if it will work.
Jul 13, 2009 | Toshiba Satellite A135-S4666 Notebook
I have ibm T21 laptop, i got 8GB pen drive it is not working
You need to download and install the drivers for your memory stick. You can do this by going to the manufacturers website (who made the stick) and  download the drivers from there.
Jan 07, 2009 | IBM ThinkPad T21 Notebook
My cinedash media console is not working the mute and volume controls are both lit up but no response from either I have Acer aspire 6920 frist my cinedash used to work, but now it stop out of the...
Hmmm just found solution to the cine dash volume control problem.
You need to shut your laptop down. Remove the battery for 10 secs. Replace battery. Boot up and all should be okay.
I have tried this on mine and it worked fine. If this does not work straight away someone else said something about LaunchManager but I didn't have to do that so can't give any info on that.
Jan 05, 2009 | Acer Aspire 6920 Notebook PC
Sound Problem
Hi.........i have a compaq presario 700 series.In my laptop if i plugged my headphone into my laptop the lap speakers cant stop working,both laptop and headphone speakers are working
Aug 02, 2008 | Compaq Presario 700 470024-192 Notebook
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
44 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
