Question about Cell Phones
I have an NEC D term i phone system with four handsets, and a previous telco supplier had set the Automatic Route Selection to direct calls to their billing system. I need to reset the XEN IPK system to the default, so my current telco can take the billing details. What is the procedure - from the handset/s or with an interface to the XEN box.
  • stevo4262 Oct 04, 2009
    Thank you
    I will see whether my new telco is now registering my calls and let you know in the next day or so
    Bob
  • 497 Answers
Sure, please go ahead.
Please feel free to get back to us for further assistance.
Good Luck!!!!!
Posted on Oct 05, 2009
    President:
  • 1,462 Answers
Please follow these steps to reset the NEC IPK SYSTEM:
  • Press Feature
  • Dial 99
  • Press Feature
Note: Resetting the Feature LED will cancel Call Forward All Calls, Do Not Disturb and Callback Request settings.so this must reset your call being forwarded to billing system.
Please leave me comment, if you need further assistance, we may help you
RNJ VINODKUMAR
Posted on Oct 02, 2009
How do I get the feature key to stop blinking?
These phones work on about 8 NEC phone systems, but most are just newer versions of the same system. So, most likely the callback feature has been activated. Someone internally calls you, you don't answer, they dial # to activate callback. You come back to your phone, see feature key flashing, lift handset, dial #, call goes to whoever set callback, then feature key stops blinking.
Jul 07, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Magicbox phone
I have a Kurio touch tablet handheld for kids the Ultimate Android cannot open it up and there was a code set for here with dots and now it will not pull up any games at all or anything She resent the code some how and it is locked
Dec 30, 2013 | Cell Phones
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
What is network selection? which is better automatic a or b ?
Most GSM handsets offer a choice to select a new network, automatically or manually. The default setting, in most cases, is automatic, which instructs your mobile to automatically connect to the strongest network signal available. As you move, the handset will continually monitor the available networks, and keep you connected to the strongest one. In a manual network selection setting, your mobile handset will detect if there is more than one network present and offer you a choice. If you then select one network, your mobile phone will remain connected to it regardless of the alternative networks available. You may prefer to remain connected to one network if it offers cheaper outgoing call charges. To manually select networks please refer to your mobile phone user manual for instructions. Your Jersey Telecom SIM card can store a list of your preferred roaming partners. If you have an automatic network selection setting, and there are two networks of equal strength available, the mobile phones will connect you to the one that is highest on your SIM card’s preferred list. The list can be edited by using the appropriate menu on your mobile phone. Check your mobile phone user manual for details.
don"t forget to say thank's
Mar 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Change Caller Id setting
CID's are controlled by the telco. You need to call them and ask for it to be changed.
Feb 04, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Can't answer direct line calls
This sounds like a programming issue on this telephone. There are 2 areas in programming that would cause this. If you have recently had a technician out to do some programming then it is possible that he made a mistake and needs to be called back to correct his mistake.
Nov 12, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Can not receive calls from the outside
Do you own that number from the telco? Is it in your DID range? Did you put it in the right call routing table?
Feb 05, 2008 | Inter-Tel Axxess Phone 5504400
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
