Question about Kenmore Dryers
Are the following parts available? A lent catcher and the plastic cover for the lent catcher for model 78415820.
  • 101 Answers
I;m sure you can get them replaced at ur local appliance store,and first try there junk pole for a model just like urs/
Posted on Oct 02, 2009
Makes a grinding noise when i turn it on
The lint screen may be too long, is it the original part? With all the fussing around, the screen holder may have gotten knocked out of place. Probably going to have to open the machine to get things straight.
Nov 26, 2013 | Samsung DV218AEW Electric Dryer
Catcher parts
Get model no. of mower. You can order flap on line or at mower repair shop. I have mine on back order now.
Jun 24, 2013 | Poulan Garden
The f-05 is flashing up on the LCD screen and washer won't spin just stops.model is wd860
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
Apr 25, 2011 | Hotpoint Washing Machines
I need apulp catcher for jack lalanne elite. it will not start because a small piece of plastic has snapped off
Available parts for the Jack LaLanne Power Juicers can be found here:
https://www.unitycart.com/pjss/parts/parts_classic.asp
You might take time to browse the site, you will find How To videos, manuals, Tips and recipes.
Mar 31, 2011 | Jack Lalanne Power Juicer (Stainless...
I can't find a grass catcher attachment for my Poulan/Weedeater walk behind model HD41486A. Help!
Hello, I did finally locate your model number in my Electrolux Home Products catalog, HOWEVER, the bag is no longer manufactured and as near as I can tell, there are no longer any available to purchase. You can still buy the frame and hard plastic top but no bag.
This is a 1995 model so this is not an uncommon thing.
I can look up the part numbers of the available items for you if you want them.
Sorry I could not present you with better news.
Chuck
Nov 04, 2009 | Poulan "Poulan" Push Mower
How can I remove the front of my dryer so I can clean out the lint? I have a brush, but it can not unclog the large amount of lint once the lint catcher is removed. Model is 110 60922990
one of the most effective ways to get this lint is to use your vacuum cleaner hose and reduce the size down using heavy plastic tubing, of a small enough outside diameter. Many sizes of plastic tubing are available at hardware stores, home depots, etc. Be sure to get a thick walled tubing that will not collapse under the suction. good luck with it.
Oct 25, 2009 | Kenmore Elite HE4 Electric Dryer
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Clothes only warm and damp after an hour
try checking to see if the vent is plugged up, this includes the lent catcher the hose and the outside ait vent.
Jun 26, 2009 | Dryers
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
