Question about Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840C How do you change out the drum in the MFC-8840C?
  • Brother Master
  • 1,113 Answers
Centre of machine is not one door but two, the first is the maual bypass tray but you can open the whole front. Then you are where you can put toner and drum in/out. Once front is open just pull entire black insides of printer slightly up and towards you, whole unit now removed is drum and toner, unclick ((blue tabs) toner from drum unit ..fit it to new drum, reinsert it, before you close the door, turn on the machine and Clear, 1. Now close the door.
LInk if paste fails
Title:
How do I replace the drum unit?
Description: Follow the procedure below to replace drum unit.
Caution
    Do NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
Brother MFC-8840C - spray1.gif Caution
    Just after you have used the MFC, some internal parts of the MFC are extremely HOT! So please be careful.
  1. Press the cover release button and then open the front cover.
  2. Remove the old drum unit and toner cartridge assembly. Place it on a drop cloth or disposable paper to avoid scattering toner.
    zl2mfc_037.gif Caution
      To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  3. Hold down the lock lever on the right and pull the toner cartridge out of the drum unit Note
      Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
  4. Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag and discard it according to local regulations.
  5. Reinstall the toner cartridge into the new drum unit
    Caution
      To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
      If you accidentaly touch the shaded part, wipe the surface with Brother MFC-8840C - drum_5100.gifee soft cloth.
  6. Reinstall the new drum unit, keeping the front cover open.
  7. Press Clear/Back.
  8. Press 1 and when the LCD shows Accepted, and close the front cover
Posted on Dec 21, 2007
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
How do I reset the drum counter on the a Brother MFC-7840W???
open the front cover of machine ( where the cartridge is installed), then press the clear button, and then press 1 for yes for change drum question.
May 13, 2010 | Brother MFC 7840W Printer
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
Installed new drum on Brother MFC-8440. Still says chnage drum soon
With new drum you got to have a instruction how to reset counter of the drum. In every packet of new drum come with instruction how to change and reset.
Dec 15, 2009 | Brother MFC-8440 All-In-One Laser Printer
When printing with my Brother MFC, the pages are dark.
Did you change the toner cartridge with a new genuine oem cartridge?
Do a report print <settings> page from the menu and check the 'Drum life' Bar graph. If close to, or at 0%, get a new Drum unit
Dec 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 8840D still says change drum soon
Open the front cover
press clear/back button
press 1 and when the lcd shows accepted, close the front cover.
thanks adi
Apr 27, 2009 | Brother MFC 8840D All-In-One Laser Printer
Changing Drum
The drum is where the image is applied before being transfer to the paper. If the drum is wearing down the image will become poor. Changing the drum unit will make the image like new. So, yes you can run the drum catridge until you get a poor print out.
Apr 24, 2008 | Brother MFC 4800 All-In-One Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC-8840D All-In-One Laser Printer Logo
216 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
