Question about Dometic Rooftop RV Air Conditioner
Furnace and Air conditioner run at the same time
I installed a new thermostat and now the furnace AND air conditioner run when the heat is on but not when just the cooler is on. Did I put a wire in the wrong place?
  • 101 Answers
Odds are u did just that or wrong thermostat,If u don't have a digrahm get one from Library.
Posted on Oct 02, 2009
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
We are trying to install a new thermostat for our heating and ac. and the wiring colors are different.
Hello my name is Heath it will be my pleasure to assist you. Red wire to R terminal on the urnace and the thermostat. White furnace and the wire to W or w1 on the thermostat nd the furnace, Use the brown wire on the W2 terminal of the furnace and the thermostat., Yellow wire to the y or y1 terminal on the furnace and the thermostat, Green wire to the G terminal on the furnace and the thermostat, Use the black wire to common on the furnace and the C terminal of the thermostat, Use the blue wire on the Y2 terminal of the furnace and the thermostat if you have a two stage air conditioner.
Sep 11, 2011 | Heating & Cooling
Furnace shuts down before heat temp meets thermostat. Furnace unit starts frequently. Service installed new limit switch and a new circuit board but furnace unit continues to malfunction. Same problems...
has any one checked your thermostat. as soon as the furnace shuts down then turn up the stat and see if it starts right up. i would think the stat function should have been checked also.
Feb 12, 2011 | Heating & Cooling
My Rheem oil furnace is coupled with Rhuud heat pump. Oil furnace runs on emergency mode only and heat pump doesn't work at all!! Now the oil furnace will not even fire up even on emode.
Try and jump it out by taking the wire hooked to R and W terminals on your thermostat and connecting them. It could be you have a bad thermostat.
Feb 11, 2010 | Ruud UBHC Air Conditioner
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
Thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Gas furnace continually running
Is the blower operating and are your air filters new
Jan 03, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
734 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
