Question about Samsung 793S 17" CRT Monitor
Even if i switch on my computer with moniter it doesnt show anything on moniter screen it remains black
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Hello. With the computer and monitor OFF, disconnect the signal cable from the video card on your system. Next, turn on the monitor. There should be a bright green box with a pink outline of a video connector inside showing. If there isn't, and the monitor is definitely powered up, then there is an internal problem. If there IS a little green box, etc., the video card in your system is suspect.
  • 1) When turning on the monitor, do you hear the sound of the high voltage initiating?(i.e. you should hear some type of electronic noise like a vibration or crackling of static on the picture tube)
  • 2) If you do hear that high voltage kicking in, it may very well mean that the picture tube is dead and getting a replacement monitor is in your future.
  • 3) If you don't hear the high voltage, quite possibly the transformer that produces it(called a flyback transformer) is defective.
Due to the vast array of inexpensive monitors available, you probably should consider getting a new unit--the cost of a new display will rival the cost of the repair--and you get a fresh warranty to boot. If the picture tube is gone, there's no choice.---Rick
Posted on Oct 02, 2009
My computer moniter take more time for switch on the moniter .it doesnt show the windoes logo it directly shows the desktop after taking more time like 5minutes.
its becuse your post bios screen is hidden you can veiw them by clicking tab on the keyboard when the printer starts it will show the post bios details
Jul 03, 2011 | Computers & Internet
My hp w2007 moniter keeps going black after about 10 mins. of idle .turned off screensaver because i want moniter to stay on but it doesnt.
Where you go to select "no" screen saver, there should be a "Power Settings" button. Press this and in there you can set the power save feature to "never" switch off monitor. Hope this helps. Ian.
Oct 21, 2009 | HP W2007 LCD Monitor
My computer often fails to start. even if the hard disk is running my moniter and keyboard doesn't show ant sign of power signal and the moniter screen just remain blank with power led of moniter blinking
Note: make sure that the computer is turned off before removing the RAM from the DIMM slot. Hope this helps.
Sep 27, 2009 | MSI 845 PRO Motherboard
Moniter doesnt show anything
ok check you video driver because if your moniter is working with other computers then that could be what it is but let me know if anything else happens
Nov 07, 2008 | Soyo SY-K7VME Motherboard
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Samsung SyncMaster 152N Just died on me...
there is something that defect on the main board power input.
Mar 16, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Screen on moniter is not full
I think that you need to reinstall or find a new driver for it.
Sep 02, 2006 | E-Machines eMachines Monitor E15T4
Samsung 793S 17" CRT Monitor Logo
106 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
