Question about BenQ G2110W 21" Monitor
I switch my pc on and it says no signal detected, is it the cable? I've tried to plug the monitor into different comps and it doesn't work any time
  • 215 Answers
If monitor showing no signal detected then monitor is working oh
Posted on Oct 02, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Try a new cable - if the issue isnt the cable then u may have a bad monitor
My Insignia Monitor doesn't work with my laptop, I've tried everything, from pc settings to cables, etc, i only receive a NO SIGNAL ad
Usually you have to toggle the display output on the laptop. The FN key + one of the F# keys with a monitor icon on it. Toggle it until it outputs to the monitor. Your getting "no signal" because no signal is being sent to the monitor or you have the monitor on the wrong input if it has multiple inputs.
Dec 24, 2012 | Insignia Computers & Internet
When my computer says check signal cable what does it mean?
Your monitor is telling you that it thinks it is not receiving a video signal from the computer. You need to verify which of three components is not working, the computer, the cable, or the monitor.
The first thing to do, obviously, is to check that the cable connecting the computer to monitor is good. You will need some extra components to do the checking. I'm going to assume that the cable is detachable at both ends.
First you can try replacing the cable with different one. If the replacement cable works, then it's the cable.
Secondly, you can try different monitor. If you connect this in place of the first monitor, and it works, it's a faulty monitor (needs repairing or replacing).
Third try a different computer with the original cable and monitor, if it all works it looks like the video on your PC has malfunctioned. (This might also be your conclusion if a system comprising a different cable and monitor fails to work with the original PC)
You might just be able to verify the cable by testing the connectivity of all the wires in the cable with a meter, if you knew the pin out of the cable at both ends.
If you find out the computer is getting a signal out, there could be many causes for that, each having its own solution (or not as the case may be)
12.April.2014
Aug 08, 2012 | HP Computers & Internet
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Compaq D315 showing no input signal
Check if the cable between PC and the monitor is tight and re-plug it.
Try using a different monitor - to check if monitor isn't broken. If another monitor works - it's a problem with monitor. It could be just a wrong chosen input - if it's true specify please your monitor type.
Try using the monitor on a different PC - if it works then you've a problem with your Compaq D315. Probably a problem with graphics.
Dec 31, 2011 | Compaq D315 Business PC PC Desktop
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Why the monitor says "no
because it doesn't receives any signal from the pc - check the video cable. If the cable is correctly plugged in at both ends then the pc is defective - test it starting with the video card.
Jul 01, 2011 | Dell E176FPC Monitor
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
No signal detected
Where the cable is plugged in, a terminal probably came loose internally. DO NOT ATTEMPT TO REPAIR THIS YOURSELF! There are very high voltages inside. Buy a new monitor or take it to a repair shop.
Jun 28, 2010 | ViewSonic VG150 15" LCD Monitor
Reverse KVM problems
If you are sure the left monitor?s power is not the source of the problem it does sound like a shielding or excessive signal loss in a device/cable. If it?s always the left monitor I would try unplugging the video cable that goes from the left monitor and plug it into the right monitor; do the same with the other monitor. If the problem moves to the right monitor then that eliminates the monitors and we move on. If the problem goes away then probably one monitor had more signal degradation than the other. If the problem stays then the monitor is the source of the problem. If the problem followed the cable then I would exchange the cables that run from the switch to the monitors; if nothing changes exchange the cables that run from the switch to the PCs. If exchanging any of these cables results in the problem moving then you have a damaged cable or a bad connection. If the problem is still on the left monitor unplug the cables from the left PC that run from it to the switch and plug them into the right PC; do the same to the right PC. If the problem moves then you might have a damaged switch OR perhaps the video card output on one of the PCs is weaker than the other. All cables and devices weaken the video signal to some degree but the amounts can differ wildly. Over the years I?ve had this problem caused by cables, switchboxes, video cards, radio transmitters, bent connector pins, poor connections, excessive cable lengths, monitors and accumulative signal loss from several devices. The last is the hardest to diagnose. Good luck and let us know what happens.
Jan 01, 2007 | APC Cables - KVM Products, Data Switches,...
BenQ G2110W 21" Monitor Logo
320 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
