Question about On-Guard Alarm with Wireless Siren, Remote Keyless Entry, and
MY CRIME STOPPER IS LOCKING AND UNLOCKING WHEN I HIT THE BUTTON ON THE ALARM, BUT I DO NOT HAVE A SIREN NOISE AND IT WILL NOT MAKE A SIREN NOISE WHEN ALARM IS SUPPOSE TO GO OFF
  • 20 Answers
A connection may be faulty on your siren or car horn you can find the manuals at www.crimestopper.com under support then choose manuals and manuals again you have to use the model number from under your dash not the remote because they may be different if that does not work you can contact their tech support at 800.998.6880 ext 210
Posted on Feb 09, 2010
Car alarm will arm but won't unarm
www.manualsonline.com/support-request.html i hope this helps good luck!
Nov 26, 2013 | On-Guard Alarm with Wireless Siren, Remote...
Remote does not work change batters
Make sure you connect the batteries correctly, if it does not work then it can be due to an internal problem in the remote control... take it to the engineer..
Mar 27, 2011 | On-Guard Alarm with Wireless Siren, Remote...
I just installed it on a 1990 mazda b2200 and the horn or siren are not making any noise. i double checked that the wires were correct and the horn requires a relay which i connected and installed. can you...
does the relay switch on alarm? check switching on with voltmeter (or 12v lamp). if not, the relay is not driven by alarm - if it does, check relays "power" side with ohmmeter or connect 12v and use lamp. if ok try another horn. if not change relay.
hope it helps
kind regards
Feb 11, 2011 | Crimestopper SP101 Deluxe 1Way Alarm and...
I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
You need to hook up the disarm wire also and depend of what car you're working on, it will disarm when you unlock the car.
Jan 13, 2011 | 2-Way Remote Starter
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
Battery died and I am having trouble getting my car to work afterwards
if the remote keyless entry remote battery is totally lowbatt. open the remote and remove the battery, for emergency option, manually recharge it by contacting + and - terminal to charger or any source of dc voltage that compatible to your alarm battery, then assemble it again and try to operated on your lock unlock system
Jul 10, 2010 | On-Guard Alarm with Wireless Siren, Remote...
How do you make the doors not lock when you start your car with a crime stopper remote start
That is a function of the security system. Are you sure you want remote start without locking the doors? I don't believe you can change the programming of that function but the user manual for your alarm should explain how if it can by done.
May 11, 2010 | 2-Way Remote Starter
Crime stopper sp 500 alarm installed in a 2002
30 seconds or minutes. If seconds then the installer taped into the dome light circuit for the door trigger and when the light turns off it's setting off the alarm.
If 30 minutes, I need more info.
Apr 03, 2010 | Combo Alarm and Remote Start with One For...
Stuck in valet mode
To exit valet mode turn the ignition on and press the overide /program button for 4 to 5 seconds until the dash LED turns off and you hear the system chirp two times. That should get you out of valet mode. Please don't forget to rate. Thanks.
Apr 08, 2009 | On-Guard Alarm with Wireless Siren, Remote...
On-Guard Alarm with Wireless Siren, Remote Keyless Entry, and Logo
466 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Frank Mangiapane
Level 1 Expert
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
