Question about GE Dryers
Will an oven light bulb work in a dryer
Will an oven light bulb work in a clothes dryer
  • 101 Answers
Why praytel are you needing a light in ur dryer for
Posted on Oct 02, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
My light bulb went out in my dryer and I bought a regular replacement bulb from home depot and it doesn't work. Does my dryer need a special bulb?
Hello Eric;
My name is Peter. I am a retired field service appliance technician.
In general all appliances require a special bulb; your oven, refrigerator - the bulbs are designed for the service - extreme hot or extreme cold.
These bulbs are expensive.
Part Number 22002263 - 10 Watt - $11.00
Dec 07, 2014 | Whirlpool Dryers
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
I just cleaned my Tappan NF40700643 Automatic Pilotless Ignition gas oven and now the light bulb (bulb is good) the and oven does not get hot .... it does nothing. Help ... I have dinner ready to put in...
if not even the light bulb is working it sounds like the plug is out or the fuse blew,pull the stove out,plug in a hair dryer or something to see if there's any power at the outlet or just go check the fuse or breaker box
Aug 16, 2011 | Tappan TGF363 Gas Kitchen Range
I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
try not to screw it on too tight.
cheers
Jan 19, 2011 | Westinghouse Microwave Ovens
Whirlpool Dryer 3.5 years old has power but will not turn on. Not a breaker problem. has electricity. Drum turns by hand. No noise is heard.
we had a very similar problem on our DLE3777W LG clothes dryer. It would power up normally, all drying options and speed and heat selections behaved normally but when you tried to start the dryer the start button and the time remaining indicator would flash until the unit was turned off. Called LG and Best Buy and they could only tell us to contact a repair shop. But I realized that the light was burned out inside, so I replaced it myself to avoid being charged by the technician I was about to call. The burned out light bulb WAS the problem, as soon as it was replaced the dryer worked perfectly. I think I saved a couple of hundred dollars with a $4 light bulb. I would have been mad to have the technician show up and charge me $120 just to show up, then an hourly rate and then the bulb.
Jun 26, 2010 | Whirlpool WED5800S Electric Dryer
I want to change the light in my microwave. Panasonic nn-p704sw. I took apart the covr and foung the light attached to a plastic scockrt. I tried to unscrew but the bulb was tight. should i apply more...
Typically the bulb will unscrew from the socket. If you can remove the bulb and socket with the wire from the microwave (wire hanging from the microwave) you might be able to get more pressure on the bulb to turn it. Keep in mind that the bulb may have been in the oven for several years and there may be a build of grease on the treads of the bulb so it could be really stuck. Put a cloth towel around the bulb and wear gloves so you don't cut your hand if the bulb were to shatter.
May 02, 2010 | Panasonic NN-P794SF Microwave Oven
Where is the light bulb located in the clothes dryer?
most bulbs are located at the front top inside the front or bottom front. usually onle needing a screwdriver. karl
Oct 31, 2009 | Kenmore 70172 Gas Commercial Dryer
Whirlpool Duet Dryer
My dryer did the same thing, all the lights worked on front, but the bulb was out inside. All I had to do was to replace the thermal fuse and replace the bulb if you want light. The bulb don't have to work in order to dry clothes
Jan 03, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
56 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
