Question about HP LaserJet 5p Printer
HP 5P wont print on Vista
I see that Cnida1 just posted a response to the same problem. I would like to get a copy of the solution 'email' they obtained. However, I can not figure out how to contact a member directly.
After much trouble, I finally got the 5P to work via a USB-Parallel adapter cable. After unplugging it, now I am back to the same problem. It won't print and the computer thinks it is 'off line". I can't seem to find the original solution I found on how to solve this problem and welcome any suggestions. I believe it had something to do with 'bi-directional' support, but I have checked the properties and it is not enabled. I am using Vista. Please help.
  • 3 Answers
I deleted the email but still have the hard copy, so here goes. This worked with my 14 year old hp and a Dynex USB-Parallel cable.
1. Plug the printer to the USB-parallel printer cable and turn on printer.
2. Plug USB end to USB port on you computer.
3. When you do this, the computer will recognize the cable.
4. Go to Control Panel/Hardware/Device Manager/USB Controllers.
5. Make a click on the + icon and check if you have USB Printing Support
(If you are not able to locate it, unplug cable from USB port and plug it
back in, so you will see something that's new on the Serial Bus
Controllers).
6. Make a double click on USB Printing Support to open a new window
and look for device status. You should see a message "This device is
working properly".
Now you need to open a new com port for the printer:
1. Go to Control Panel and click printers & faxes.
2. You will see an icon there with the name of your printer, make a right
click over it and go to Properties.
3. Select the Port tab and on the display menu select Virtual USB Port.
If you have more than one select no. 1 first. If it does not work, select
Virtual USB Port, and so on. (The virtual port will depend exclusively on
what the printer requires).
4. Click Apply and try to print a test page.
I first hooked this up putting the USB cable into a port on the front of the computer and it worked fine. I then moved it to the back of the computer and it did not work, so I just had to go to the process again until I found a USB prt that worked. It has worked just fine ever since. This solution was given to me by Dynex Prodlucts customer care team. I am no techie and don't understand any of it, but I can follow instructions and it was successful. Gool luck.
Posted on Oct 04, 2009
Does the hp laserjet 5p make copies or is it just a printer
This is just a printer, not a copier.
Thank you,
Lee
May 22, 2011 | HP LaserJet 5p Printer
How do I copy with a HP Laser Jet 5P
You cannot COPY with just a printer. You'll need a SCANNER too. Basically, you use the scanner to scan the page, then you print it using your printer.
Mar 28, 2010 | HP LaserJet 5p Printer
Hp laserjet 5p will not print with new computer (Vista)
check cable for error take a other printer to try
mostaly if you connect usb in the usb port then it select the poort 1 or 2 or 3 and find the printer if you chanche it for a other poort it wil not see the printer
Sep 27, 2009 | HP LaserJet 5p Printer
Vista will not print to HP Laserjet 5p
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
LaserJet 5p extra page prints first with code
When you get that kind of information those are instructions to the printer. It has been my experience that the drivers loaded for the printer are not the correct ones. Check to make sure that you have the drivers for a HP 5P printer and verify that is what kind a printer you have.
Oct 28, 2008 | HP LaserJet 5p Printer
I recently installed my hp laserjet 5p printer yet its not printing
Is the driver installed? Do you see it in the printer section/
Nov 11, 2007 | HP LaserJet 5p Printer
Printer is out of memory is ther solution to this
Hi 92366, If your printer all of a sudden started giving you ?out of memory? errors while printing things you could print before, then you might have a problem. First thing to do is print out a copy of your printers configuration and verify how much memory the printer thinks it has. If it?s different from what you physically installed you may have issues with you memory. If you are trying to print large graphics they you simply may just need to increase you printers memory. If you?ve got plenty of memory, you haven?t changed or done anything to cause this error and you?ve been able to print this material before without errors here are some things to try: The 5P doesn?t have a display screen I?m assuming you?re getting this error in Windows. What is the status of the LEDs on the printer when you get this error? If you or anyone else with a similar problem is so inclined here is HPs LED code sheet: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl04302 Try deleting your existing printer queue, downloading a new copy of the appropriate driver and reinstall. Here is the link to the HP site, simply select your operating system, select and download the appropriate driver. I personally am more partial to the pcl 5e driver and avoid everything else, in particular the PostScript drivers. Here is the HP link for their LaserJet 5p drivers: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15011&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25481&debug=Keynote If none of this works let us know what happened that seems pertinent. Good luck and please don?t forget to rate the posting.
Jan 12, 2007 | HP LaserJet 5p Printer
HP LaserJet 5p Printer Logo
341 people viewed this question
Seeker5211
Seeker5211
