Question about GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur...
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
We have a 2002, GE Artic Profile Refrigerator, side-by-side. Two weeks ago, the refrigerator side heated to 100 F and all food spoiled. The GE tech changed the main computer board. Three days later, heated to 80 F, food spoiled. The GE tech changed the light switch. About fours days later, the same thing again. GE service is stumped. Any help is appreciated.
  • Anonymous Mar 16, 2014
    Refrigerator does not turn on
  • Anonymous Mar 27, 2014
    after 2 days vegetables will be spoiled likely to put in water.
    President:
  • 878 Answers
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Posted on Dec 20, 2007
Fluctuating Freezer and Refrigerator Temperature
check the freezer evaporator thermistor on the top left corner clipped to the evaporator,if its not 16k ohm when at 32 degrees in a glass of ice water after 4 minutes it will defrost too many times and cause this issue,you need to unplug the J1 connector on the mother board in the rear behind the cover and check terminals 4 & 5 un the plug,not on the board though
Feb 07, 2013 | Refrigerators
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
FREEZER COILS KEEP ICING OVER AND MAKING FRIDGE AND FREEZER NOT COLD, FOOD SPOILED.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Erratic temperature control. Freezer temperature varies from -4 to +2 even though set to -1, refrigerator also with wide variation. refrigerator is about 2.5 years old and this is a new problem.
Unles this is a big change and is not affecting the fresh food sect temperatures.Those should be 38 degrees for food safety. As far as the temperatures measurements those are easily altered by placing articles of packages near the thermistors in freezer and fresh food compartment. There are many issues you need to consider with the model refrigerator Artic/Profile. They are very sensitive to power surge and simple failures. Hopefully your being only 2.5 years out GE has resolved the problems of the past.GE is a good company and they do support their customers through the 5 year sealed system replacement. There are very many models of your type. Could you send me the model number listed for example PSS26MRSS. If you could I will get you some information that can help you save you repair cost in the end, Now if there is a problem with the thermistors we will need to resolve that because it will cause more problems later. Thanks Sea Breeze
Nov 10, 2009 | GE Profile¿ Arctica® Energy...
R door- GE 21.6 is slipped down. Gasket cant seal, part needed?
the parts detective dot com has all sorts of repair parts. You'll need the model and possible the serial number.
Aug 11, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur... Logo
236 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
