Question about Cell Phones
Everytime I try to open my camera it has a black screen and says, ''Could not start the camera. Close other applications and try opening the camer again.''
Can't access the camera it will display this message everytime i click on the camera COULD NOT START THE CAMERA. CLOSE OTHER APPLICATIONS AND TRY OPENING THE CAMERA AGAIN.
Your default storing of images is perhaps phone memory. If you have sd card in your phone then change the storing of images in MEMORY CARD. May be this way your prob could be fix up.
Jan 11, 2011 | Cell Phones
Could not start the camera close other applications and try opening the camera again blackberry
could not start the camera close other applications and try opening the camera again blackberry
Dec 07, 2010 | RIM BlackBerry Pearl Smartphone
Everytime I open my camera it always say that it cannot open and try closing other application first and try opening again the camera but I'm pretty sure I've already close all of my applications. What...
You will have to get the phone warrantied through your provider. You have a bad camera in the phone. I have replaced alot of these camera which causes the application to close.
"Please leave me a testimonial or feedback if this helped you, thanks"
Oct 27, 2010 | RIM BlackBerry Storm 9530 Smartphone
Whenever i open up my camera it says "could not start the camera. close other applications and try opening again."
Hi, when a camera says could not open the camera close other application and try again ,means that either to much application where opened at a tie or the camera is corrupted.
First, scan through phone and see if unnecessary applications where open,If not, that means the camera is faulty and will eeed to be replayed.
Aug 07, 2010 | RIM BlackBerry Bold 9700 Smartphone
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Sony Ericsson W350i camera not working
sony ericsson camare problem...when i will start camare ,,display message 0 hold ,,another application running ,,close to start
Jun 27, 2009 | Sony Ericsson W350i Cell Phone
My camera is not working/ black screen.it tells me to close apps
Alright, I just had this problem. I dont know how this happened, but some settings were changed. If you go to media and press the menu button then go to options. Now change device memory limit to 15mb and reserved picture memory to 2mb. Now try your camera, it worked for me.
Jun 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
Screen Is Black
there are two possible problem of your camera..1 may be the iris is not opening..try to look at inside of the lens you should see the iris will open when you turn off and on the the camera at the camera mode..if the iris in opening the 2nd problem maybe is the image sensor is deffective..in this case you have bring it to the service center....
Aug 29, 2008 | Samsung 1.5MP High-Definition Digital...
Blackberry 8130 Curve Camera Troubleshooting
I had this problem and I've tried everything posted and nothing worked so I just started messing around with my phone and may have figured it out. Here's what I did.
NOTE: I AM NOT RESPOSIBLE FOR ANYTHING THAT HAPPENS AND YOU ARE SOLEY DOING THIS ON YOUR OWN AT YOUR OWN RESPOSIBLITY. Good Luck
1. Click the Menu Button
2. Scroll to Options Icon (the wrench) and click it
3. Click Advanced Options
4. Click Applications and wait for the Apps to load.
5. Scroll down and delete the apps that you dont need (see what I deleted)
6. I first deleted ICQ Messanger by scrolling over it and selecting the menu button then clicked delete, then clicked Yes and let it reboot
7. After it rebooted I clicked the Camera button on the side and it worked after I rebooted
8. Then I went back in and deleted Yahoo Messanger and let it reboot again. (This is up to you)
9. Last I deleted Windows Live Messenger and let reboot once again. (This is up to you)
I deleted these because I didnt use them anways. These were the only 3 apps that I deleted since I never used them. If you want, you could even delete Brick Breaker if you dont play it but I wouldnt delete any other Apps other than these.
Jul 01, 2008 | Cell Phones
Cell Phones Logo
171 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
