Question about Ramp Networks WebRamp 700s Router
Setup hooking up cables
  • 556 Answers
Hooking up a router is often more that just hooking up cables. Some internet service providers ISP's (phone/cable/internet companies) have requirements to be configured into the router to allow for communication with their networks. Unless you are sure you understand the ISP's requirements perhaps you could provide a link to the ISP's support website or his name. Confirming the manufacturer and model of the router would be good too just in case the one in the heading of this message in incorrect. If you provide the required information in a comment to this message I will attempt to provide steps to hook up your router.
Generally starting with either a cable or a phone wire out of a phone jack a connection is made to a modem (often supplied by the ISP) the modem is generally connected with an ethernet cable to the wan side of a router and the router is connected from one of 4 lan ports with an ethernet cable to a computer's network adapter. There are variations on this cabling that substitute USB cables or Wireless communications.
Posted on Dec 21, 2007
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
Just got tv yesterday, hooked regular cable wire into outlet on tv labeled cable/antenae, tv works, but not receiving cable channels
when you go into the customer setup menu in the channel scan area make sure the set is set to cable also us ez setup if that does not solve your problem return it
Nov 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Just tried to hook my aoc 22" to high definition
I beleive you have to enable audio in the HDMI SETUP so it will send the digital audio through HDMI ports, check the cable box and the TV HDMI sound setup.
Nov 19, 2010 | AOC L22W861 22 in. LCD HDTV
How can we view cable TV when the TV doesn't have a tuner?
Ur tv is a digital tv.Just buy a Digital antena or a roof antena hook it up.Go to SETUP menu go down to CH. SETUP pick AIR,not CABLE and than enter to scan.After ur tv done scanning,u will get all the free air DTV channels.
May 01, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
Setup wizard doesn't locate wireless router.
Any old ethernet cable should be fine. The setup disc is generally used only for initial setup to establish communications between router and pc, and to also configure your internet providers settings. You can access your router from your pc by going to http://192.168.1.1 and you can change settings in the router from there instead of using setup disc. If you insist on using the setup wizard disc you usually have to set your computer's ip address to a specific number and possibly reset router to default state (see manual or http://www.linksys.com).
Jan 22, 2009 | Linksys Wireless-G WKUSB54GS Kit
Ant/cable
your box might be blown out
also call the cable company to see if the outage didnt affect them
they might be out too
on the TV you might to look for setup or init setup
a model number of the tv set wouldnt hurt too
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jan 06, 2008 | Curtis-Mathis CM19011 TV
Channel Setup
it's saying that because the antenna is hooked into the same thing, the coaxle jack. It shouldn't memorize any chanells that don't come in on the antenna. It's been a long time since I had mine hooked to an antenna but I know it'll work if you let it go through the auto setup. If need be unplug the unit for like two minutes so it's memory is erased and then fo form there. I hope this helps
Jan 02, 2008 | Emerson EWD2202 DVD Player/VCR
Having a problem with netgear
Hook up the Cable from the DSL or Cable modem to the Router. Run one cable from the router to your main computer.
Open up Internet explorer and type in 192.168.0.1. or 192.168.1.0 to access the router setup . Run the setup wizard,
Dec 04, 2007 | NetGear WGR614 Wireless Router
Ramp Networks WebRamp 700s Router Logo
121 people viewed this question
Top Ramp Networks Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Ramp Networks Computer and Internet Expert? Answer questions, earn points and help others
