Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Lf code on whirlpool cabro - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • cappe May 11, 2010
    need more info
    President:
  • 1,653 Answers
The LF code indicates the washer has taken longer than 8 minutes to fill and as a result has not satisfied the pressure switch that the machine is filled with the required amount of water. This may result from having a low water supply pressure, which can happen if you have a bath, sink taps or hose running while trying to use the machine. This condition can also result if the drain hose is too far into the stand pipe or runs down hill into a floor drain and effectively siphons out water from the machine. Check the drain hose and correct it if either of these are happening otherwise check to see if you really do get enough water flow and pressure on the cold, and if you have a dual fill machine, the hot water supply. It is also worth checking to see if the filter screen at the end of the supply hose is clogged or scaled up in which case you should clean it or descaler it as appropriate.
Posted on Oct 02, 2009
My whirlpool cabrio is reading LF and F1
Your Cabrio is continuing to fill (Long Fill) past the set limit, causing a Flooding potential.
Oct 05, 2016 | Whirlpool Washing Machines
My cabrio whirlpool washer automatically restart new wash
Well, is it LT, or LF? They mean completely different things.
Jul 16, 2016 | Whirlpool Washing Machines
Whirlpool washing machine with error code FL
Dos your machine sometimes continue to fill Fl could be LF I have seen the codes pop up different than the tech sheet anyway LF is a long fill wish I could tell you the exact location of the service manual WP always moves it try on the inside of the bottom panel first if not there look inside might be mounted on wall a few times located under top panel read it it will explain how to place machine into diagnostic usually on LF the unit is draining slow or the black hose that leads to the pressure switch has popped loose a rubbed against basket pulley causing a small hole in the rubber this will give a LF error hope this helps
Feb 13, 2015 | Whirlpool Duet WFW9250WW 4.0 Cu. Ft. Front...
What does whirlpool duet error code lf?
Lf or long fill could be a multitude of many. Is the water turned on, is the hoses kinked , the water inlet screen clogged, water lines crossed, bad or faulty water inlet valve, or faulty pressure switch.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Overfilling Whirlpool cabrio washer
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
Jan 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
293 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
