Question about SanDisk Sansa Clip MP3 Player
Sansa connect computer will not recognize
Have windows xp with sp2. when i try to download
and installing the driver wizard or there site I keep getting an error that the installation failed. can not find a driver for it or get it to work.
not a tech person for this type of mesdia player.
My sansaconnect 4GB mp3 is telling me to recover it and I need help
Posted on Dec 12, 2009
Sent it back could not fix it with any of the suggesstions.
Posted on Oct 02, 2009
My desktop (XP Pro SP3) does not recognize my Sansa e280
Try to unplug/replug the player or better try to connect it on a different USB port then after that restart the computer that should do the trick..
Hope that helps.....
Sep 04, 2008 | SanDisk Sansa E280 MP3 Player
My mp3 player does not recognized by computer, i want to load some music. how do i solve it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
The Sansa player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Instructions to connect in Forced MSC mode are listed here:
http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit
for more answers at:
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
or http://kb.sandisk.com/app/answers/list/
Mar 03, 2010 | SanDisk Sansa e250 MP3 Player
Cannot be reconized by computer, ie states no device connected
Try other USB ports on your computer. A USB port behind a PC usually has the most power output. Try a different cable if there's one available, to rule out a cable malfunction. Try another computer.  NEXT - Refresh the drivers STEP 1 - Connect the Sansa player to the PC STEP 2 - Check under Device Manager -> 1. Right-click My Computer, and select Manage. NOTE: The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode.)
See this tip posted here on this site. This might be what is going on with your player.  http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.  STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. A brand new Sansa player NOT recognized by the computer when plugged in: This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.   To resolve this issue, try the following solutions: Verify if minimum operating system requirements are met.
Operating systems supported by Sansa players: Windows Vista and Windows XP SP2
Windows Media player supported by Sansa players: Version 10 and 11 Download and install the latest Windows Media Player if it's not installed.
For MAC users, see Sansa player not recognized by a MAC OS Next Connect the device to the PC in MSC mode View/c200:  Turn on then press and hold the rewind button while plugging to the PC  See List of Sansa players with instructions on enabling MSC mode
If all this has failed - Refresh the drivers
STEP 1 - Connect the Sansa player to the PC STEP 2 - Check under Device Manager 1. Right-click My Computer, and select Manage. SOLUTION 4 - If that didn't work, and you are running Windows Vista, verify if you have Service Pack 1 installed.   If all that does not work - Manually add the hardware driver. STEP 1 - Connect the Sansa player in MTP mode STEP 2 - Manually install the device driver 1. Click Start select Control Panel then select Add Hardware. 2. Click Next to begin the Add Hardware Wizard. 3. Click Yes, I have already connected the hardware, then Next. 4. Scroll to the end of the list and select Add a new hardware device then click Next 5. Select Install the hardware that I manually select from a list (Advanced) then click Next 6. Select Portable Device or Windows Media Device from the list, then click Next 7. Select MTP device, then click Next. 8. Click Next to start loading the drivers. 9. Click Finish to close the wizard.
STEP 3 - Verify if the device is detected properly 1. Double-click My Computer. 2. Check if the device is showing up under Portable devices. SOLUTION 6 - Set user restrictions.
Some computers have user right restrictions that are set to disable access to new hardware. STEP 1 - Log-in as an Administrator STEP 2 - Edit restriction NOTE: Disconnect the Sansa player if connected. 1. Click Start then Run, 2. Type cmd, then the press Enter. 3. After the prompt, type Net localgroup Administrators local service /add then press Enter.
STEP 3 - Reconnect your device
Jan 10, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Computer does not recagnize MP3 player when connected
4. Power issue.
- Run the hotfix.
if u want more help u can go with these site:
http://www.doremisoft.net/Sansa-articles/Convert-video-to-Sansa-on-mac-osx/
wish above can help u solve your problems.
Jan 06, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Can't use VPC-CG9 as PC camera.
I don't know why this wouldn't work on Vista HP, but this excerpt from the manual suggests that your XP SP1 Pro would not work without the SP2 rollup:
"Please perform the following upgrades before connecting the camera to a computer.
-Upgrade Windows XP to SP2.
Install Windows XP SP2.
-Install Windows Messenger 5.0 or later version.
Download Windows Messenger 5.0 or later version, and install it.
-If using MSN Messenger, please install MSN Messenger 7.0 or later
version."
Perhaps if you are following the steps exactly in the manual and it still does not work, upgrading Messenger will magically help.
Mar 24, 2009 | Sanyo Xacti VPC-CG9 Digital Camera
My sansa mp3 player isn`t recognized by the computer
It may depend on your operating system, but there are known issues in vista. There is also a hotfix from microsoft. This is from the Sansa Website FAQs at http://www.sansa.com/support/sansa_clip/faqs
My Sansa player is not recognized by my computer when I connect it.
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
On the Clip: Go to Settings > USB mode & choose MSC
I hope this helps and please don't forget to rate my answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa e-260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
310 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
