Question about HP Compaq Presario V2000 Notebook
What type of hard drive adapter or converter can I(a novice)use to transfer data from my v2000 laptop to another laptop or to a desktop computer?
  • 3,153 Answers
Almost any external device that your USB port will support.
If you want to move a lot of information then a proper external hard drive at least as big as you internal hard drive (preferably bigger) Also try select one that has its own power suppy
You really to use USB 2.0 ports for external drive of any sort to be in with a chance.
If you need any more information just ask.
Posted on Oct 02, 2009
    Guru:
  • 355 Answers
Use pen drive for safe data transfer
Hi there. When talking about USB 3.0. Can say say that there is a USB 3.0 hard drive? Or can I say that if I have an external USB 3.0 hard drive case and place a hard drive in it it would have the USB
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Nov 03, 2012 | Computers & Internet
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
I've got an old dell laptop from which I want to accesss the photos and documents but the power won't stay on..the green power light stays on for only a few seconds then goes off! please help?
Get hold of a desktop computer that is working. Open the Hard Disk Drive cover of your laptop. Pull out the Hard disk. Get a cable (an example is Nexstar universal storage adapter) which can be used to connect your laptop Hard disk to the desktop via USB port. A desk top allows multiple drives. This way you can get the laptop HDD as a seperate drive in your My computer, (like you see a pendrive or a CD drive. You can try reading this drive and copy content to the desktop. Pretty easy to transfer data and a useful device to have. You can find this device at http://www.amazon.com/Vantec-NexStar-Universal-Storage-Adapter/dp/B002PXFZ3C
Jun 14, 2010 | Dell Latitude CPI Notebook
Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Nov 14, 2009 | HP Compaq Presario V2000 Notebook
How you transfer data from laptop to desktop? Is there any utility available?
Hi
Thanks for using FixYa. You can connect the Laptop with your Desktop using USB cable or Memory Stick and transfer the data. You can also write the data on a CD and then transfer it to desktop.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Compaq Presario 700 470024-192 Notebook
Can PC hard drive cable be converted to a USB cable?
Try USB2 to ISDE & SATA cable adapter
OR
why not put that 1 st drive into the other computer if compatible.. BIOS should auto detect if it's connected to 2ndry chanel
Oct 27, 2009 | Gateway Computers & Internet
Hard drive adaptor
Your laptop HDD uses a newer connection type called SATA. The one you are used to using is called IDE. They do make adapters to go from one to the other but they are hard to find and not very reliable (sometimes just dont work).
You can find a 2.5" (laptop size) hard drive enclosure for SATA to USB at almost any electronics store.
Double check your motherboard (on your desktop if thats what you are using to read the drive) for SATA connectors on it. Many computers have been using SATA almost as a standard since about 2004-2005, but some may not still have it.
The reason for the new type of connection is faster data transfer speeds.
To look at the differences, click the link below:
http://jekkilekki.files.wordpress.com/2009/06/sata-ide-laptop-hard-drive.jpg
Oct 16, 2009 | Toshiba Satellite P105-S6104 Notebook
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Hard drive recovery
sorry to say but you would have to spend probaly $100 at best buy
Jun 23, 2008 | HP Compaq Presario V2000 Notebook
Transfering data from one desktop to another
sol 1 you can burn your data in dvd or cd
sol 2 you can transfer your data in thumb drive (pen drive)
May 31, 2008 | Dell Dimension 4600 PC Desktop
HP Compaq Presario V2000 Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
