Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera takes videos of trees and grass blowing. Stills are Block
Camera takes videos of trees and grass blowing no problem. But no animals. Still pictures come out with blocks of color, can't recognize anything in the picture. Is there a driver or software to download to fix the problem?
How to use the flash when I take a night video? with a nokon coolpix p900
You can't. The flash, as the name implies, is for a short burst of light, useful for taking stills but not for video. For video, you need a video light, something that stays lit for a longer time.
One example of such a device is Flashpoint On Camera LED
Please note that I am NOT endorsing this particular device, or any other.
Sep 18, 2016 | Nikon CoolPix 900 Digital Camera
A200 faulty selector switch
Same thing happened mine. Take out battery and leave camera for a few weeks until internal cell goes flat. Switch to "stills" mode and put battery back in. You will need to reset the date and time. LEAVE SWITCH IN "STILLS" mode for ever more.
Dec 31, 2011 | Konica Minolta DiMAGE A200 Digital Camera
My kodak easyshare C143 lost the sound when I make video.. Can you help me?
Your camera hasn't lost anything. It's a very basic and cheap model which is primarily a digital stills camera. Although it can record video, it does not have the hardware to record audio.
You get what you pay for and so having a very rudimentary video recording function keeps the price down and makes sure that the primary camera function is still satisfactory.
Your fix, if you want sound with your video, is to either get a dedicated video camera or to get a more advanced digital stills camera with full video and audio capability.
Jul 01, 2011 | Kodak EasyShare C143 Digital Camera
I recently used ROUNDUP on a lawn The product did its job, the weeds are gone, so is some of the grass near the spray. It has not rained since the spay went on - maybe 10 - 12 days. How can I restore the...
Your grass is probably dead as well. Roundup is a non selective herbicide and will kill anything green. So take care when applying. Even green stems of young trees. Shield from spray when spraying. The best is to plant new grass. Roundup stays active in the soil for around two weeks despite what Monsanto says so add new topsoil when laying new runners or a new block of grass. Rain is no issue except within 6 hours of treatment. You can water the lawn with no problem now. Good luck and take care-Roundup is a poison that does affect our hormonal balances especially women.
Aug 04, 2010 | Roundup "" Weed & Grass Killer
Converting a video file to a still
There is nothing on the camera to convert videos to stills. You can do so on a computer using video editing software. Bear in mind that you won't get very much quality. Even HD video is only about 2 megapixels, a far cry from the stills your SD1100 is capable of.
The best advice I can give you is that next time, when you want stills you shoot stills.
Jul 05, 2010 | Canon PowerShot SD1100 IS Digital Camera
Which is best nikon coolpix s3000 or samsung hmx u10
Best for what? The answer depends entirely on the sort of pictures you intend to take and also the price you want to pay.
The Nikon is a stills camera with some video capability, the Samsung is a video camera with some stills capability. They're completely different.
If you want to take mostly stills, then go for the Nikon. If not then get the Samsung. it's a very poor video camera and an even worse stills camera, but the video quality is far better than on the Nikon. The Nikon is a very capable stills camera and worse than the Samsung for video.
If price is a major factor then the Nikon typically costs £90 and the Samsung is typically £80 (current UK prices).
May 19, 2010 | Nikon Coolpix S3000 Digital Camera
It wont take pictures
Determine how the camcorder works. There are 3 basic modes of capturing stills with a camcorder. Read your instruction manual for specific information.
  • Step 2 Understand freeze-frame stills. The most common and least effective method is a "photo mode." Basically, the camcorder will simply freeze a frame of video for a few seconds, which can then be extracted later as a still.
  • Step 3 Use editing software to capture stills. This method is similar to the first, and can be done with any camcorder. Download an editing program or use the camcorder's bundled software. Then transfer the video over to your computer and use the software to pull out stills.
  • Step 4 Understand built-in digital cameras. This is a more expensive option, but results in higher quality photos. These cameras have built-in memory cards and function basically the same as a stand-alone digital camera. Refer to the manual to switch over to digital camera mode, then point and shoot. The photo quality is usually a bit lower than from a stand-alone camera.
  • Step 5 Compare specifications. Understand that specifications for high quality video don't necessarily translate to high quality stills. CCD determines the quality of video, while megapixels determine the quality of stills.
  • Step 6 Consider the value. Whether or not a combination digital camera and camcorder is best for you depends on how you'll be sharing your photos
  • Mar 18, 2010 | Video Cameras
    How can I take stills with VL-Z1
    You need a memory card, you should be able to get the right one. You import just like you would footage. Hope that helps.
    Apr 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
    How to turn on/off the flash onthe samsung d900i phone
    Using camera options in Capture mode
    In Capture mode, press < ebdd9ac.gif > to access the following
    options:
    Record video: switch to Record mode.
    Shooting mode: take a photo in the following
    modes:
    Single shot: take a photo in Normal mode. You
    can select whether or not the camera automatically
    saves a photo.
    Multi shot: take a series of action stills. You can
    select the number of photos the camera will take
    and the shooting speed.
    Mosaic shot: take several stills and save them in
    one frame. You can select the layout.
    Effects: change the colour tone or apply a special
    effect.
    Frames: apply a decorative frame.
    Flash: determine the use of the flash.
    Timer: set a time delay before the camera takes a
    photo.
    Go to My photos: access the My photos folder.
    Camera settings: change the default settings for
    taking a photo.
    Apr 01, 2008 | Cell Phones
    PC Wont register Camera is connected
    If it is a cam corder, a lot of them only work for stills once hooked up to the PC (via USB). Are you certain the cam be used via a computer.
    If the camcorder contains both USB and IEE1394/firewire and your computer has both USB and firewire, then sometimes the USb interface is set to stills only and the firewire interface is set to motion only.
    Which make/model?
    Feb 27, 2008 | Cameras
    Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
    37 people viewed this question
    Top Moultrie Cameras Experts
    Steve
    AZBen
    AZBen
    Are you a Moultrie Camera Expert? Answer questions, earn points and help others
