Question about Nokia Cell Phones
I've lost my owners' manual and need to know how to pair a Jabra bluetooth device to my Nokia 1530.
Sorry! I was being really stupid. My phone isn't a 1530. It's a 5310. I've found the manual and all is well. Thank you.
Posted on Oct 02, 2009
    President:
  • 1,462 Answers
First you have to enable the Bluetooth to scanning mode,
To do this, press and hold the power button continously for 10 seconds, you may have a stable LED, this shows that its in discoverable mode, Now perform scanning for bluetooth device from your phone and you may get your device and you can pair and make it work with code 0000 .
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
My speaker tower ITB123B will turn on, and will connect to bluetooth, but will NOT play music. Not from bluetooth and not from Radio. Is there a way to reset the device?
suggest following page 10
http://www.brandsmartusa.com/pdfs/manuals/20174760.pdf
and try to pair again with devices.
Had do you this on a jabra bluetooth speaker that was dropping the bluetooth and it fixed it ?
do not know how it .lost the pairing by itself but re doing the pairing fixed the jabra
Nov 07, 2016 | Cell Phones
I have a Jabra Bluetooth headset after updating my phone with Nokia Ovi Suite I lost all my games and my paired things on bluetooth. I tried 4 times to pair the Jabra so have locked it out of my phone how...
hi, you can solve this problem in a simple method- press the power button of the bluetooth device continuously for 2 or3 s check the light of blutooth device is turned on then go to bluetooth device option on your mobile phone and select add more device the time pair the device by using this code 0000
was this helpful to you
Aug 27, 2010 | Nokia 6300 Cellular Phone
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
How do i pair sp 500 to my nokia n95 mobile
The Jabra user manual is located below - you'll need to reference it to determine which button is the Pairing button. After you turn on the Jabra, press and hold the pairing button until the blue light is solid (approximately 2 seconds). Set your phone to discover mode as follows:
Go to the Bluetooth menu under the Tools menu item
Select Options > New Paired device.
Select the device and enter 0000 as the passcode.
If you want the device to automatically pair when they are within range of each other, select the device and select Set as authorised.
That's all there is to it.
Feb 20, 2010 | Lands Phones
How To pair Jabra A125s with Nokia BH-604 bluetooth headset ?? Need Help !!!
Turn ON the bluetooth headset (keep the button pressed for few seconds) and bluetooth connection of your Nokia phone. Search for the device from your phone, when found enter the pass key "0000" (its default) when prompted, set this device as authorized to pair it.
Jul 02, 2009 | Jabra BT125 Headset
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Security code for nokia 6126 pairing with a jabra 250 bluetooth
hey! if you want to pair the bluetooth if 00000 mean same code want to give the pairing device then only you can pair the device! other wise use single digit 0 or 1.
all the best!
Sep 21, 2008 | Nokia 6126 Cellular Phone
How to pair Jabra SP5050 to Nokia N76
I just had the same problem pairing the Jabra SP5050 with a Motorolla Razr but then realized the default setting on the Jabra is auto-pairing & that may not work with few phone that "discover" bluetooth devices. Solution: Turn off the Jabra SP5050 by pressing the answer button for about 5 seconds; then turn it ON by pressing it 7 seconds (contrast to the normal turn ON with fewer seconds - the bluetooth light should flash continuously) Now the speaker is in manual pairing mode; use the phone's normal discover bluetooth to locate it.
Apr 18, 2008 | Cell Phones
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
Cell Phones Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
