Question about Texas Instruments TI-83 Plus Calculator
Vertical lines, numbers look funny - Texas Instruments TI-83 Plus Calculator
  • Texas Instru... Master
  • 8,073 Answers
Check this article. It will show you how to force the reinstallation of the OS. If that does not solve your problem, you may have to send calculator for service.
Hope it helps.
Posted on Oct 29, 2009
When you turn on set a lot of vertical scramble lines
Turn off, disconnect power for a couple of hours and try it again.
If vertical lines still there google for your model number and vertical lines. If it is an LCD version set then youtube search for your model number and repair. Sometimes it takes a baseball bat!!!!
Feb 10, 2015 | Televison & Video
I have a 42" hannspree TV and first it went funny and it caused a light vertical line down the middle, since then it has improved but now when I turned it on a white flashing on the right side of the...
12" in diameter or 12" in width. Vertical or Horizontal. what does funny mean? Your less likely to get a good diagnosis if you are not specific with the symptoms.
Sep 13, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Vertical lines on screen kinda pixelated
Just check this link. You can see similar type of fault to LCD TVs. Compare them to that of your TVs and make sure. It sounds that the LVDS cable has loose contact with its connection sockets. Re-seat it once, and check.http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Polaroid Televison & Video
Vertical line that won't go away
Try another monitor just in case your video card is doing something funny - if that display works fine, you need to replace your monitor
Hope this helps, Sherwin
Dec 21, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Transducer is mounted on a plastic bracket to trolling motor. when trolling motor is turned on, black vertical lines appear on my screen. lowrance x107 cdf
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Aug 23, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Scanning a black vertical line down the left side of the document
funny thing. I cleaned it. I had looked before, but didn't see the line on the surface of the glass so i thought it was internal. A closer 2nd look revieled a distinct line on the surface of the glass, probably from pen or marker ink that wasnt dry.
Scanner repaired, pride slightly damaged. thanks for the response
Jul 22, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
White lines on screen
im sorry my friend I do not understand what a funny marrior is? LOL If your complaining about white lines at only the top of the picture, then I would say that your problem is with the vertical sweep circuit. Most likly a capacitor in the vertical preamp really small ones next to the jungle IC or the capacitors that are used as waveshapers in the vertical drive and output. If the entire screen is white lines then the screen drive is too high so back it down till the lines just disapear. if that wont turn down, theres a filter cap on the sweeop supply or the CRT socket board is bad. Good Luck
Oct 08, 2006 | Toshiba 32HFX71 32" TV
Texas Instruments TI-83 Plus Calculator Logo
120 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
