Question about Maxtor Hard Drive
I have aproblem with the my hard drive. It noises as tuk tuk and also not working.window xp bar runs and after that monitor show "Insert disk failure system" i have very important data in it how can i repair it. i donot want to loss it. any none can help me to get rid of this problem.
  • 3,153 Answers
This is not a good sound at all i am afraid
If you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If the information is mission critical then there are very expensive data recovery places you can send the drive to but this can cost from $400 upward !
NB !
! ! DO NOT PLACE A HARD DRIVE IN A FREEZER ! !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
If I keep collecting "frozen hard drives" at the rate i do i will soon have enough to build a small house
Posted on Oct 02, 2009
    Guru:
  • 355 Answers
Your had disk is dameaged (problem with disk or connceting card )give your har disk to any experts and get your data back
My lacie harddisk doesn't show up in windows XP. Power is ok. Light is on and he makes normal operating noise like always. I have another one for which I use the same USB-chord and that one is working...
1. right click the my computer
2. go to properties
3. click hardware tab
4. and click Device Manager
5. show the Device Manager and click disk drives
6. your hard disk is show or not.
7. it's show then go my computer properties
8. select manage and show computer management window
9. then click disk management
10. your hard disk partitionis show right click the partition add driver letter (ex: h:, i: ..)
11. after open the my computer the partition is show
thankyou
Sep 15, 2010 | LaCie F.A. Porsche (301177) Hard Drive
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
When I plug in my western digital TB, computer wont recognize it anymore, it is a macbook,
though very incomplete data abt ur system config..
however, u gotta know, is ur system compatible handling such..
some system needs the hdd controller driver or firmwire at the time of os install..(eg we press n select driver using F6 while in case of winXP*, in such case u need a floppy n floppy drive)..
bring ur ear closer to the hdd n make sure that it does not make any noise (like 'tuk tuk' or 'kirr kirr')..in such case itz probably gone bad n need to b replaced..
in some cases, if more than one hard disk r running, esp in case of PATA, look for jumper settings..(master/slave)..
in some cases, if more than one hard disk r running, esp in case of PATA+SATA, look for bios settings if is in native/compatible/enhanced mode, try fixing as necessary..
if ur nt a professional, contact ur system admin/vendor....
Nov 16, 2009 | Western Digital My Book Essential 1TB...
My computer is not recognizing the WD. The USB Port are working fine its recognizes other external devices
Nov 13, 2009 | Computers & Internet
The PC no recognize this disk
Nov 12, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Verbatim
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
Jan 14, 2009 | Verbatim 160GB USB FireLite: The "drive...
Not able to open windows
Sounds like a hard Drive problem. A virus actually. The Best thing to do if Safe Mode Failed is the Repair Your system, to do this insert your XP CD and wait until it says 'Press any key to boot CD' Press any key and follow instructions to repair windows. If it works, run a virus scan immediately. If Not, take it itno a computer technitian to look at it if you want the stuff on your Hard Drive, of if you feel you don't care too much just wipe the Hard Drive and Re-Install Windows XP. just do the same thing as repair but instead follow the instructions for Installing XP and choose either Clear or Erase Hard drive if you don't want the info or choose don't clrear or Erase if you really want stuff from your hard drive, But run a Virus scan Immediately asap.
Hope This Helps
Nov 18, 2008 | Compaq Presario M2000 Notebook
External hard drive
I found that explorer doesn't show a drive that isn't partitioned. I went to the Disk Manager and it shows up there. I right clicked for new partition and assigned it a drive letter. My problem was fixed. Windows XP
Disk Manager. under:
Control Panel, Admin. Tools, Computer Mgr, Disk Manager.
Aug 26, 2008 | Computers & Internet
Maxtor Hard Drive Logo
64 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
