Question about Phase Linear UDV9010 Car DVD Player
After 2 minutes on a treadmill, Jenny has a heart rate of 82. After 3 minutes she has a heart rate of 86. Assuming that Jenny's heart rate H is a linear function of the time T on the treadmill, write H as a linear function of T. What heart rate would be expected for Jenny after 10 minutes on the treadmill?
  • 75 Answers
Zero, if shes over 90
Posted on Oct 02, 2009
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
Jan 22, 2013 | Ironman Exercise & Fitness
Does the odor treadmill measure heart rate without holding on to the grips
Are you sure you have the correct brand of Treadmill. Never heard of this one.
Double check your brand and model. IFIT is availalable on several brands and models of treadmills, it is possible that your treadmill only has heart rate grips and also possible it will do both.
Generally a treadmill that will work with a heart rate strap will say so right on the face.
Dec 05, 2010 | Heart Interface Ifit Treadmill My Progress...
Give me an example of polynomial age word problems with solution.
Sep 22, 2010 | M2K Garfield: It's All About Letters and...
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
May 17, 2010 | Precor C956i Treadmills with HR /...
Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
May 22, 2009 | Polar F6 Wrist Watch
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Seeing heart rate displayed on my polar compatible treadmill
i didnt knwo my treadmill was compatible i just hooked up like i wanted to read from my watch and then both started to read...although the treadmill had a bit of a different reading
Jan 02, 2009 | Polar S410 Heart Rate Monitor
HRM Support
There are five easy steps you should take: 1. Roughly estimate your maximum heart rate (MHR) by subtracting your age from 220 (or a little more accurately, 214-(0.8 x age) for men, and 209-(0.9 x age) for women. If you're a regular runner, you can test yourself for your MHR by warming up and then doing a combination of short, fast runs as follows, ideally on a treadmill: run as fast as you can, evenly, for three minutes, then rest with two or three minutes gentle running, then repeat your three-minute maximal run; at some stage during the second effort you should get a higher MHR value than with any other method. 2. Work out your training zones: 50-60 per cent of maximum for easy recovery runs; 60-70 per cent for basic weight management; 70-80 per cent for aerobic training; and 80-100 per cent for threshold runs and speed training. The figures are more accurate if you find percentages of your working heart rate, then add them to your resting heart rate. You find your working heart rate by subtracting your resting heart rate from your maximum. 3. If you don't already have a training schedule, plan your runs for the week ahead and allocate a target heart rate zone for each run. 4. Stick to these zones. 5. Be alert for unusual readings. If you're ill, tired, stressed or not fully recovered from a race, then your resting heart rate may be higher than normal. If it's 5-10 beats above normal, make your day's run an easy one. Any higher than that and you should definitely have a rest day.
Aug 27, 2008 | Welch Allyn Mobile Stand for Spot Vital...
Phase Linear UDV9010 Car DVD Player Logo
171 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
