Question about Leviton Decora Gray Rocker 4-Way AC Quiet Switch
Can i test a four way switch with a meter?
Will a continuity test on a four way switch tell me if the switch is broken?
  • 308 Answers
Yes, you should have continuity between two screws, two times (total of four screws) If you have continuity between screw 1 and 2, then you should have continuity between screw 3 and 4. You should not (in this example) have continuity between 1 and 3 or 4. Hope this helps
Posted on Oct 02, 2009
How can i tell if the hi limit thermostat in my maytag wall oven is bad
test with a multi meter on each end of the wire prong connector, place each end of ur meter prong on both 1 and 2 of the connectors, and test for continuity ohms or a close circuit. have ur meter on a low ohms setting as the level of ohms is low. if it shows an open circuit or no continuity, its defective. Infinity is the meter not showing anything like a number 1 and not moving?
Apr 26, 2015 | Maytag MEW6530DDW 30" Electric Single Wall...
Error code e08 mc fills buzz as actuator starts but motor failsa to cut in will continue to fill and drain within cycle bur never turn motor
first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
If both check ok then next CHECK the motor coupler (a bad couplercan be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? )
or belt if belt driven. Check for loose, broken or worn belt .
Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Also check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub)
Remember to check the agitator spline as well. for worn broken teeth
By the way my advice is free cuz God is good!
Mar 27, 2015 | Hoover Dynamic 8 DYN8144D White 600 mm...
Power button not working
3 possible sources of your problem. It would really hgelp if you have a continuity meter to check it with. With the saw unplugged, connedt the meter to the plug terminals. It should show no continuity. Press the saw trigger and the meter should show continuity. It probably won't since the saw is not working.
What you will need to do now is use the meter to isolate the problem. There are several possibilities:
- Broken electrical supply wire
- Switch not functioning
- Armature brushes not making contact.
Test each component separately and You will find the problem.
Mar 07, 2015 | Saws
My Proform XP Trainer 580 started to speed up while I was running. The lights all still work and tell me the speed but speed up on there own. Recently it completely stopped working. The motor is not...
Dear Sir:
Thank you by your request, I hope everything is fine.
I will try to help you inmediately.
Connectthe test leads to the volt-ohmmeter. Plug the black test leads into the blackjack marked "Com" or "Common" on the front of the meter. Plugthe red test lead into the red jack marked "Volts/Ohms" on the frontof the meter.
    • 2
Setthe meter's function switch to "Ohms" and the range switch to the"R x 1" scale. If your digital multimeter is an auto ranging meter,you will not have a range switch. Instead, you'll have just a function switchbecause the meter will automatically select the right range for the quantitythat you are measuring.
    • 3
Turnoff the power and remove the fuse to be tested from the circuit. Never test afuse for continuity while it is still connected to the circuit that it is usedto protect. If the circuit still has voltage, the meter will be irreparablydamaged. If the fuse is still in the circuit when tested it is possible to geta false indication that the fuse is good if the meter gets a completed circuitthrough other circuit components. To be safe, always remove the fuse from thecircuit before testing it.
    • 4
Touchthe black test probe to one end of the fuse and the red test probe to the otherend of the fuse. It does not matter which probe you touch to which end becausefuses are not polarized. You are checking to see if there is continuity throughthe fuse element. A reading of approximately 0.5 on a digital meter's LCDindicates a good fuse. Most digital meters read their own internal fusesresistance, hence 0.5 Ohms and not 0.00 Ohms. LCD readout of "O.L."indicates no continuity through the fuse. The fuse is bad and needs to bereplaced.
I hope that you can Handle the DVOM(Digital Voltimeter)
Thank you in advance, sincerely. Blessing.
E.CUADRA MANAGUA,NICARAGUA. C.A.
Sep 28, 2011 | Proform XP 580 Trainer Treadmill
2003 Elantra GSL power windows don't work.
could be the driver side master window switch... if the driver side window switch assembly is broken then the windows will not work... try using a test light to see if you got power to the with and and ohm meter to check all four switches on the drivers side
Jul 11, 2010 | Hyundai Motor 2003 Elantra
My saw is just making a clicking noise when i depress the lock off button and trigger switch,can't get it to work.
You either have a break in the cord or the switch is open (broken electrical circuit). Sometimes the cord will get pinched or wound and the wires inside will break. A quick way to test a cord is to crimp the cord in your hand the entire length from the plug to the handle while holding the switch in the on position. If there is a break somewhere crimping the cord should make contact for a couple of seconds and you will get some power to the saw. The best way to check is to use a multi meter to check the continuity of the cord. You will have to remove the switch from the housing and use your meter on the cord. Set your meter to the ohms function and test the continuity of the load and line wires. (Touch one lead of the meter to the blade and the other to the corresponding wire that goes into the switch. Hint the polarized blade side - wide side- is the white wire and the smaller blade is the black wire.) If you have continuity through the wire you can check the switch next. Locate where the cord wires go into the switch and the other two wires that come out. Test at these two points while depressing the switch. If you have continuity in the switch and the cord you need to check the carbon brushes to see if they are worn or broken. If you need any assistance please post back and I will help.
Sep 27, 2009 | Ryobi Circular Saw W/Dual Laser
No power to sunroof?? however fuse is fine??? of the four wires black,green,purple,and orange what wire preforms what function??? ie" power in ground open close
BLACK MAY BE YOUR GROUND AND THE OTHER WILL BE HOT DEPENDING ON WHAT MOVEMENT YOU ARE DOING ON SWITCH YOU CAN TAKE TEST LIGHT AND SEE WITCH ONE LIGHT UP WHEN YOU PUSH THE SWITCH THAT MAY TELL YOU IF YOU HAVE SWITCH ISUSE OR MOTOR ISUSE TEST LIGHT YOU CAN BUY CHEAP OR IF YOU MAVE TEST METER THIS CAN WORK TO HOPE THIS HELPS
Sep 12, 2009 | 2003 Chevrolet TrailBlazer
O2 Dodge Dakota Brake lights wont work but bulbs r good.
If the bulbs are good I would suspect the Brake light switch.
Brake Light Switch: Testing and Inspection
The brake lamp switch can be tested with an ohmmeter. The ohmmeter is used to check continuity between the pin terminals.
Switch Circuit Identification
- Terminals 1 and 2: brake lamp circuit
- Terminals 3 and 4: RWAL/ABS module and Powertrain Control Module (PCM) circuit
- Terminals 5 and 6: speed control circuit
Switch Continuity Test
NOTE: Disconnect switch harness before testing switch continuity.
With switch plunger extended, attach test leads to pins 1 and 2. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 3 and 4. Replace switch if meter indicates no continuity.
With switch plunger retracted, attach test leads to pins 5 and 6. Replace switch if meter indicates no continuity.
Sep 11, 2009 | 2002 Dodge Dakota Club Cab
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
A Question
You can test the humidistat fairly easily, using a volt-ohm meter. Just set the meter to RX1 scale and attach its leads to the humidistat's terminals. Rotate the humidistat's knob as far as it will turn in both directions. If the volt-ohm meter registers zero ohms through only part of the humidistat dial's range, the humidistat is working. If it registers zero through the entire range, it's broken and must be replaced. Dehumidifier Overflow Cutoff Switch Test- Using a volt-ohm meter, you can tell if the overflow switch works or not. Clip the leads to the terminals on the switch. Depress the bar or trip lever on the switch. If the meter's needle doesn't show continuity and no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
Jan 18, 2006 | Fedders A7DH65B2A Dehumidifier
Leviton Decora Gray Rocker 4-Way AC Quiet Switch Logo
866 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
