Question about Maytag Neptune MAH5500B Front Load Washer
How do you pull the bearing on the rear of the neptune 5500bww it has failed and I need to replace it
    President:
  • 1,304 Answers
You dont it is pressed into the tub
this is a complete tub job
Posted on Oct 05, 2009
Neptune 5500bww isnt draining has new drain pump now power going to new drain pump everything else seems to be working fine
You need to check the drain lines to make sure that they are clear. Don't forget to check the discharge line that it is clear as well. Some units have a filter as well that may need to be cleaned.
Apr 26, 2014 | Maytag Neptune MAH5500B Front Load Washer
Matage neptune washer loud in spin cycle
The rear bearings are going out. The motor will overheat from the increased load and the motor control board will soon fail unless this is fixed.
Here is a link to the parts you need.
Oct 14, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune very loud in spin cycle what is wrong
The rear bearing is going out. The motor will overheat from the increased load and the motor control board will soon fail unless this is fixed. To replace the Maytag Neptune rear shell bearings first order the seal and bearings. Here is the kit.
Oct 14, 2012 | Washing Machines
I have a maytag front load neptune. The door is locked but does not show that it is lock on the panel, it will not wash but will not open either, how can I get the door open?
they seem to have a issue with the doors on theses machines whirlpool owns maytag now
they were sued very bad for theses issue
The older Neptunes, such as the 2000 Stackers, MAH3000, MAH4000 and the MAH5500A series had some issues which I am sure Maytag has corrected these issues in the newer machines...
There are thousands who have been burnt by the door latch wax motor failure. What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11) and a triac (Q6).
However, if Neptune owners know to replace the door latch wax motor they can prevent the control board failure from happening. Please tell everyone you know about this important fact.
The older Neptune's also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
In addition, I just now started offering a bearing and seal kit for the Neptunes because when the bearings fail Maytag wants you to replace the whole outer tub for a service quote of around $900 or so. Why replace the whole outer tub? Just replace the worn bearings and 12002022 seal... See http://www.neptunebearing.com for the Neptune bearing kit information.
The older Neptunes run great once you take care of some small details...
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Neptune 5500BWW goes cycles but no spin?
Sounds to me like your repairman should be able to make short work on this. I may be mistaken but I would almost bet that your problem lies in a broken belt or a worn pulley. Most competent repair guys should be able to fix that within a couple of hours.
Other problems it could be are sticking pullies, a drum that is sticking, or a bad motor. Any of which should be easily fixable and cheaper than buying a new machine.
Jul 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
My machine make too much noise
does it sound like a 747 about to crash in your house? if so you might as well through your washer away because you have a bad bearing and the cost to repair that is about the same for a new one. let me know if this helps
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer MAH 5500bww seems to run OK, but it does not pump out all the water(pumps out some) at the end of the cycles, churns remaining water during spin
Open the rear panel and remove the drain pump and clean it.
If there is nothing in the pump, check the drain motor for 18 ohms with a volt/ohm meter.
Not 18 ohms, replace the motor.
May 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bearing
Dear friend,
ngfam at you service!
The Neptune was discontinued for 98 design defects!!!!!!!!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Neil
Jul 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
127 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
