Question about Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2)
Steering wheel is a little off set, how do I fix it.
What does the little black button do. I don't have instructions. And how do I fix the offset of the steering wheel.
    Sergeant:
    Champion:
  • 208 Answers
Open your control panel. Click on "Printers and other hardware". Click on "Game Controllers". Then click on the wheel controller. From there, you should be able to assign the buttons and fix the offset.
Posted on Oct 02, 2009
Testimonial: "It got me to the point where I could mess with the configuration. But it in itself wasn't much help."
My car shakes at 60 nd pulls to the left nd my steering wheel is offset a little what could be my problem
You have a tire out of balance or possibly starting to separate and you need to have the front end inspected and/or aligned.
Aug 19, 2015 | Cars & Trucks
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
How do I change the external temp readout from Celsius to Fahrenheit on a 2010 Ford Explorer XLT?
There should be an option in the menu on your dash. There will either be three different buttons in a couple different places. Check the steering wheel, above or below the radio, or under the dash dimmer control located on left of the steering wheel. The buttons will always read info/setup/reset in that order. Press the setup button and look for the temperature control setting and follow the on screen instructions to reset it. Or if your car is the newer version there will be 4 arrows and an ok button on the left of your steering wheel. Use the arrows to scan through the dash screen and scroll to either setting or convenience, do the same thing. follow the on screen instructions and you should be set.
Jan 04, 2015 | Ford Cars & Trucks
How to enter radio code,which i have,into Renault radio fitted to a T35 van year 2001it has a steering wheel remote OE
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
Jul 08, 2011 | Car Audio & Video
How to put a laguna radoi code in
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code ) ============================================================
Jun 14, 2011 | Car Audio & Video
How to fix my acura integra 1994 maintenance light
Directly under the steering wheel should be a little black box with a blue button on it. Depress the button until the MAINTREQD light turns off. Tuffys couldnt figure that out either... dont feel bad.
Nov 23, 2009 | 1994 Acura Integra
Logitech steering wheel is not steering...all other buttons working trying to play nascar driving....do not have instructions manual
Go into controller settings in the nascar 09 game and select the steering wheel setup that is correct for your wheel.
Jun 26, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Violent shake
My Death Wobble started immediately after I installed a set of Coil Spring Spacers (to lift 1.75 inches) on my 2005 Jeep Wrangler X. Turned out, the DW was because while changing the height, I also lowered the CASTER angle in the front end. So, to fix it, I could have purchased a set of eccentric bolts for $50+. Instead I went out and purchased a piece of 1.5 inch flat bar for $10 from OSH. I cut out 4 1.5 inch squares. Then i drilled 7/16 inch holes centerline, but close to one side (in exactly the same place) on all for squares. I then removed the lower control arm bolts, nuts and washers. I installed these square offset washers I made so the front axle would be pushed forward (to increase the Caster angle). The toe setting changed a bit, so I reset them to about 1/8 inch toe in. After driving my Jeep, I noticed there is no more DW. The steering wheel was off center, but after 3 attempts, I have that perfectly centered. I have every intension of having the alignment checked, but not till after I find the new tires I want. If anyone is interested, I can draw out and photograph the cure and send it to you. My e-mail is bb62471(at)yahoo(dot)com.
Oct 10, 2008 | 2004 Jeep Wrangler
Blinker/light stem fallen out of steering column
CENTER the steering wheel/wheels straight ahead. Remove the air bag using the proper Torx driver. Unplug the wiring connector. Using the proper socket, undo the big nut that holds the steering wheel on. Now, bang the steering wheel left/right/left/right hands until the steering wheel comes loose. Now, here is where it gets a little tricky. There is a round black circle with a yellow tag with red letters. Put tape on it to keep it from rotating right or left. Remove the 4 screws. DO NOT TURN THE ROUND THING. If you turn it, you may damage it. Now, remove the screws that hold on the headlamp switch. Unplug the connector & bolt in the new switch. Easy, as long as you do NOT move the setting on the round thing. This is the air-bag "clockspring".
Jun 20, 2008 | 1998 Toyota Celica
Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2) Logo
801 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
