Question about Maytag PYE2300AY Electric Dryer
Changed thermal fuse and cleaned out drier. it ran good for about 20 minutes and then shut down again. what could be the problem
  • 71 Answers
Changing the thermal fuse was a good idea but if the dryer runs for 20 min. then shuts off that is generally the motor going into thermal overload....thus meaning you would need a new motor.
Posted on Oct 02, 2009
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
Samsung r40 shuts down after running for about 20 mins, was told cooling fan was not working so stripped down laptop cleaned fan (was full of dust) reasemmbled and ran all day yesterday, switched on this...
The CPU fan may be faulty and not spinning freely.
If you had removed the heatsink off the CPU did you place new thermal grease/paste on the CPU before installing the heatsink back on the CPU?
Jun 02, 2011 | Samsung R40-K009 R40-K00A R40-K00D"...
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
My Hoover U6458-900 shuts off after a few minutes of vacuuming. I let it set a few minutes and it will start up again.
It sounds as if the motor has overheated at some point, and damaged the thermal protector fuse in the motor compartment. Clean the filters thoroughly, change the bag, and try to operate it. If it still shuts down, the thermal protector will need replacement. ( Part # 47534032 )
Mar 02, 2011 | Vacuums
We have model 11502 air purifier. Recently turned it on and it ran for a few minutes and then stopped. Motor sounded fine- no squealing, didn't slow down before it went off- just stopped like it was...
Yes there is a thermal cutoff that will shut the motor off for a period of time to protect it from getting to hot. If this is what happened after 20-30 mins. the motor should come back on and run again. If it does I would try to clean motor as best I could using a soft brush, vacumn, and blow out with air if possible. Clean fan of f as best you can to help motor run cooler.Hope this helps.Thank you
Jan 05, 2011 | Honeywell Air Purifiers
What will cause the thermal fuse to continually blow.
shorted motor or heating element, which causes excessive current draw would be the cause, replace the heating element first.
Aug 28, 2009 | Kenmore 63942 Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Dryer runs for about 20 minutes when good and hot then shuts off.
suspect motor overheating and shutting down on thermal..if dryer does not have good air flow through vent to outside lint can accumilate around motor causing overheat and motor failure try cleaning around motor but i suspect it's too late damage has probably already been done
Nov 20, 2008 | Kenmore 63942 Dryer
Maytag PYE2300AY Electric Dryer Logo
325 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
