Question about Cameras
Own a polaroid pdc 5080, can't find manual, how do you set date and time and exit menu?
In polaroid pdc 5080 digital camera no longer save the date.my camera doesn't save the date .every time when i start camera its ask to set the date first.
I have that problem with my camera too but after a while... I gave up retype-ing the date and time, so know every picture is on Jan.1st 2004 at 00:00:00 :D I have tried as many things as I could TO fix it but.. nothing came through...
Jun 18, 2010 | Polaroid PDC 5080 Digital Camera
My polaroid pdc 5080 digital camera keeps shutting down
I looked at all the settings that you are able to change on MY camera and no.... you can't.... I was wondering that too a while back and I had to just give up on that.... :D hahaha.... but I hope this helped....
Jun 04, 2010 | Polaroid PDC 5080 Digital Camera
Can i use my polaroid pdc 5080 as a web cam
I'm pretty sure you can't, it takes video but not live video.... sorry...
May 18, 2009 | Polaroid PDC 5080 Digital Camera
Polaroid pdc 5080
 pls download the manual, memory card , compatability is a problem . panasonic,scandisk,toshiba only  will work. if you put other m cards , the picture will be very bright-negative effect
Mar 09, 2008 | Polaroid PDC 5080 Digital Camera
Polaroid PDC 5080
if you don't use it (press a button, take a pic., take a video, etc.) then it will turn off because say you put it in the case and forgot to turn it off, then it won't stay on and waste the battery.
Jan 30, 2008 | Polaroid PDC 5080 Digital Camera
How to activate night vision mode in polaroid PDC 5080?
there isn't a night vision mode i don't think... I've had this camera for a while and i havn't been able to find it.... BUT .... I did find something else that you could use sometime...
1)click the MENU button (M)
2) click left 3 times
3) then you have options for auto, daylight, cloudy, tungsten, and fluorescent.
sorry I could help you with your origional problem but at least now you can change some settings. :D
Sep 05, 2007 | Polaroid PDC 5080 Digital Camera
Camera forgets the date. asks for dae setup every time I put on the camera may be even after 10- 12 minutes. hough the batteries remain inside & are fully charged. I have tried by setting default settings...
Will the camera work without this item set up or does it stall there? If it works otherwise, just live with it. There is not a 'repair option as such- you could check out the Polaroid Web site tech support team though
Jul 12, 2007 | Polaroid PDC 5080 Digital Camera
Polaroid pdc 4055
Take batteries out- leave for an hours or more re insert batteries and follow set up procedure in the manual
May 12, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
