Question about HP Compaq dc5000 PC Desktop
I have a dsl lan conected by wire with pc but the networking is not stating i take some drivers from net but they also not working please help me about drivers
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
You need to assure that your system is set for DHCP
1. go to control panel then network connections
2. locate the wired connection then go to properties
click all the obtain automatically buttons
3. when finished right click the wired connection and hit repair
if all was done correctly it should obtain an ip address and be ready to go - good luck
Posted on Oct 02, 2009
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Apr 08, 2012 | Dell Inspiron 6400 Notebook
My down load is very slow
Hi,just check your speed from here http://www.scanmyspeed.com/ and if still your speed continues to be slow contact your provider.
Mar 08, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
My computer will conect to the internet on wireless but not on hardwire conection what should i do
It can be several problems.
1. Driver of wired network adapter is not properly installed. Try reinstalling the driver. 2. Your LAN wire is defective. Try a different wire. 3. If you are using a router or switch. There might be a problem with it. Check that. 4. Your wired network settings is not properly setup. Try resetting it to default.
Feb 13, 2011 | HP Compaq Presario V2000 Notebook
How to set up wireless network connection can't conect to the internet
1st If the wireless card driver is not installed then the driver.
2nd. Check Device Manager to see if the wireless card is working and enabled.
3rd. Configure the wireless card with the Wireless router's wireless settings, ie, SSID, WPA or WPA2 encryption etc.
4th Connect your DSL or Cable modem to the WAN/Inernet port with a LAN cable.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 11, 2010 | IBM ThinkPad A31 Notebook
Need usb drivers--ADSL 2+ router
Very simple indeed, buy a switch or wireless firewall. You should NEVER use high speed (always ON) connections straight to a PC without filtering anyhow. Go to Staples, Best Buy, Walmart, or wherever and ask them for a Cable/DSl Router.
This (and of course a second network cable or wireless) will alleviate all of your problems. And why do we not have a location in your area?
Dec 28, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Ps3 wired connection
Hi There.
If your PS3 is Networked upto Your PC to use the internet connection, You have to allow the PC to share its Internet connection with yout PC, Do this By going into Network settings, Checking the properties of your LAN card in your PC. and clicking on, "share my internet". This should alleviate that problem..
Or.
If your PS3's Wired connection isnt working. but your PC one is, Try moving your PS3 Lan cable into one of the other Free LAN Ports (if available) or Try Switching the PC cable over to the PS3's Port in the Router, and Visa-Versa !
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Problem with net connection
please, i want to know how to solve this problem that my laptop is demanding for the updated driver for realtek adapter before i can be connected through wireless mode
Aug 30, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Network
hii you conect net server pc . all pc conect in switch ..then your name all pc diffence .. and net conect server pc then go net conection dailbox properties ..networking ....enabil network conection then so server pc auto ip address....apply ok  done
Jan 08, 2008 | Computers & Internet
HP Compaq dc5000 PC Desktop Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
