Question about Dryers
Roper Model #RES7745RQ0 Electric Dryer Wont turn on.
I have a Roper Model number RES7745RQ0, It ran fine this morning and now it wont turn on. I have by-passed the thermal switch by directly connecting the blue wires to each other and hitting the start button, it clicks but nothing else. Could it be the ''push to start'' switch? The dryer is only 3 years old.
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
docjohn174
  • 943 Answers
SOURCE: my ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Posted on Dec 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: Drum will not turn
If the motor is not running and the heater glows red you have a defective start switch on the motor.
Posted on Apr 15, 2009
pride applia
  • 232 Answers
SOURCE: Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Posted on Jul 01, 2009
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
My Roper dryer ran a cycle with no heat then when I turned it off and tried to turn it back on...it will not come on at all. What might be the problem, I have checked the electric source and it is fine.
Hello, It is possibly the thermal fuse. Be sure to clean out the vent hose and the vent pipe to the outside to prevent over heating. If the vent system is ok then replace the thermostat as well as the thermal fuse. You can goto - http://www.searspartsdirect.com/partsdirect/index.action - to buy parts and get a parts breakdown of most brands. Just enter your model number and select model search.
Good Luck
Mar 12, 2011 | Roper Dryers
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
Dryer will not turn on.
Robert, this sounds like your motor is out. Depending on the age of the dryer, you might want to look into anew model or replace your motor. While you're in there, clean out all the lint real good! Hope this helps you!
Aug 14, 2009 | Roper RES7646KQ Electric Dryer
Drum will not turn
ok power to the motor but is motor spinning? also check pully make sure its secured to motor shaft.
Apr 14, 2009 | Dryers
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Roper Dryer Won't Turn On
Quick check list starting with the most likely to the mostly likely NOT:
Fuse edfbadd.jpgmounted on the blowers housing this puppy is wired in with the door switch. If the lint in the dryer gets to blocking the exhaust then this puppy gets all hot and bothered and melts, causing the whole machine to come to a screeching halt just as if you have opened the dryer door. Clever ain't it? Clean out the lint and replace this fuse.
Dec 31, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
114 people viewed this question
Top Dryers Experts
