Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
Fridge light goes on and off
When i open the door on the refrigerator the light will go on and then off continuously
    Sniper:
  • 68 Answers
First check if the bulb is screwed in all the way. If it is, unplug refrigerator and take the bulb out. In the bottom of the socket (where you screw the bulb into) there is a flimsy contact that the bulb touches when screwed in, use a screw driver or needle nose pliers and bend it up so the bulb will have good contact. Replace the bulb and see if this fixed it. If it still isnt fixed, it is the door switch. Ive had some that were just getting gummed up and needed cleaned and lubrication, and some that just needed replaced. They are cheap and easy to replace. Let me know if you have any further questions. Shane
Posted on Oct 02, 2009
Fisher and pykal all fridge beeps all the time, the bulb was blown, taken out (no spare at home). Will the fridge continue to work without a bulb
If you're talking about the light that goes on when you open the door, then yes It will. The light bulb has no effect on the operation of the refrigerator.
Feb 15, 2017 | Fisher Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
How to disconnect or isolate door open alarm for fridge & freezer
Disconnect the door switch, this will stop alarm but light won't work
Dec 20, 2015 | Refrigerators
New integrated baumatic fridge freezer installed yesterday but the door sensor alarm keeping going off..door is def shut. As baumatic gone into administration has anyone got any ideas plse?
It's telling you it has a fault, you have to find out who is doing the warranty work for Baumatic now, by law they have to honor the warranty.
Nov 30, 2013 | Baumatic Refrigerators
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
INTERIOR LIGHT GOES ON AND OFF
next time it does this unplug for 20 mins and pcb will reset its self....
Sep 28, 2009 | Hoover HFA290K Bottom Freezer Refrigerator
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Jun 26, 2008 | Kenmore TRIO 77314 Side by Side Bottom...
INSIDE LIGHT
I'd say the door switch is bad. Jiggle it. Spray some WD40 into it. But ultimately, remove it and test it for continuity. If there is no continuity in the door-open position, replace it.
But be careful. Some refrigerators have a second door switch with opposite function. It turns the fan OFF when the door is opened.
Jun 05, 2008 | Candy CPCA270FFK Bottom Freezer...
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
