Question about Bose 901 VI Main / Stereo Speaker
How do I connect my 901"s to my amp "NAD" 7600 power envelope ?
  • Kimbo too May 11, 2010
    need some more details.
    Brigadier General:
  • 8,546 Answers
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the Speaker B terminals. The reason is that the 901's require the uyse of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
You can use them in either of two ways.
Attach the Active Equalizer in your Tape 2 loop, following the clear guide printed on it. Activate Tape 2 to place the EQ in line with the program. Bypassing Tape 2 would show you what 901's sound like without their custom EQ curve. NEVER set the Copy function to 2>1 as this would introduce 901's EQ to whatever is on Tape 1.
or (recommended)...
TO preserve the use of your Tape attachments (through which you might also run any other kind of sound processor), remove the jumpers between the Pre Out and Normal In and attach the Active EQ there.
Should you anticipate using this rig in a multichannel setup from an AV receiver, just draw the AV receiver's Front L&R out from its Pre Out connectors, or from one of its Tape Out connectors, and into this amp's CD or Video Sound inputs. You would still have the flexibility to use the NAD for your Stereo-only rig, and your AV receiver's stereo sources would be available to it, too.
This is essentially how I run my 901's as the main speakers in my 7.1 home theatre.
Posted on Dec 05, 2009
Can i hook up a power amp to my Nad 7155 receiver and how
If the Nad has pre-amp out sockets that are currently connected to the power amp in the receiver. Then you can sever those link and put the pre-amp out into your Aragon inputs.
Otherwise I don't see how you can connect the amp.
Aug 10, 2016 | NAD Audio Players & Recorders
How to connect it to NAD C-372
Download manual from the Web.
Follow instructions.
Enjoy.
Jan 12, 2016 | Bose 901 Series VI Direct/Reflecting...
Where can I find a schematic to show me how to hook my NAD T744 to my Bose 901s?
You don't need a schematic. Google "Bose 901 manual" and read it. The speakers get hooked up to the speaker terminals on the NAD and the EQ is connected to the Tape Out and Tape In on the receiver. When you listen, you must engage the Tape Monitor (check the NAD manual on how to do that)
Aug 10, 2015 | Bose Audio Players & Recorders
Nad 7600 receiver
Power up without the speakers off, if the problem still exist, check output and driver transistors for leek or short.
Apr 03, 2014 | Audio Players & Recorders
Will the NAD T748 drive the bose 901 speakers?
Yes, the Bose user manual
http://worldwide.bose.com/axa/assets/pdf/owner_guides/StereoSpeakers/901vi_guide.pdf
says that any amp with 10-450 WRMS is OK. The speakers impedance is given as 8 ohms, so the amp is compatible.
Note that Bose say you have to have the Bose equalizer connected as well.
Sep 04, 2013 | NAD T748 Home theater receiver with...
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
How do you connect a nad c270 amp to the bose 901 series vi equlizer and system/
Bear in mind that 901's require exclusive use of any amplifier they use. You shouldn't expect to use conventional speakers alongside them on the same amp. The reason is that the 901's require the use of their dedicated Active Equalizer to shape the frequency spectrun to match their drivers' response curves, resulting in a flat sound output. Applying that kind of equalization to any conventional speakers will sound to sharp at the extremes and may even potentially damage them.
For connection I would run a pair of RCA cables from the L&R Audio Line OUT of whatever preamp or source you're using to the Active EQ's Line IN; then the EQ's Line OUT to a NAD amp's Line IN. DEselect any Tape options on the Active EQ, attach the 901's to the new amp, set the NAD volume controls pretty high (and leave them alone), run through any level setup procedures in your control electronics for volume, etc and you're done.
Aug 17, 2010 | NAD C270 2-Channel Amplifier
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
Aug 25, 2009 | Bose 901 VI Main / Stereo Speaker
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Can I connect a power amp to this unit?
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Jul 27, 2008 | Sony STR-DA2100ES Receiver
Bose 901 VI Main / Stereo Speaker Logo
351 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
