Question about Panasonic MC-E583 Bagged Upright Vacuum
Shark V15Z how to change the belt
I see no instructions on how to replace the belt. Nor do I see a way to reach it!
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and you're ready to go. Now if Shark will only help customer locate a replacement belt you may find this info useful...
Posted on Apr 22, 2010
Take the flip over cover off. Looking from the top, the screws are on the right hand side. One is for the wheel and the other just helps hold on the side plate. After taking off the screws, and pulling the plate, the roller will drop out. Put the belt on the drive pin, make and 8, and shove the roller back through. NOte that the roller has squares on the end that has to match up with the cowling. When pushing the roller through, mount the inside one first, then get some pliers, and pull up on the roller by grabbing the brushes, and then put your right hand side plate back on. Put the screws in, and the the cover plate. Ed C
Posted on Oct 24, 2010
  • 101 Answers
Look from underneath there should be atleast 3to4 screws holding plate in place.
Posted on Oct 02, 2009
Shark instruction manual
How do I change belt on shark navigator NV35627?
Jan 04, 2014 | Shark Vacuums
My Shark v15z gets very hot to the touch when you use it. I replaced the belt and still gets really hot. Any suggestions
check the electric motor airvents,and surrounding vents.make sure motor is getting plenty of ventilation.should feel a fan working
Apr 16, 2011 | Vacuums
How to change a belt on a shark v15z vac. tks john t
John -
Your vacuum doesn't have a belt - only vacuums with rotating brushes use drive belts.
What problem are you having - why do you think you need to change the belt?
Please rate my solution if you find it helpful.
Oct 14, 2010 | Euro-Pro HEPA Shark EP035 Bagless Handheld...
Broken belt on infinity vacum
You may find the belt for your vacuum through the link below. Unfortunately the only way that Shark sells this belt is with both belts as a set, you can not purchase each indiviudal belt separately.
I have also uploaded the instruction manual for your vacuum in a .pdf file on Fixya. Please note that it may take sometimes up to 24 hours for the manual to show up. Please check the following link over the next 24 hours. This instruction manual gives you step by step instructions on how to replace the belt, and also contains diagrams that will help you follow along.
Here's the link where the instruction manual will be downloaded. The belt change instructions are on page 15:
http://www.sharkclean.com/manual/NV31_REV_0706.pdf
Here's the set of belts that go on the Euro-Pro Infinity Upright model NV31, Shark Part Number 1085F:
http://www.govacuum.com/eushrebesetf.html
I hope this was helpful to you in solving your belt problems. If this was helpful please rate the repair helpful by clicking on the thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 25, 2010 | Euro-Pro NV31 Infinity Vacuum
The belt broke on my my SHARK Model V15Z and Euro Pro hasn't responded to my request for a new belt w/ directions as how to effect repairs.
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
Feb 28, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
I have a Shark Bagless Cyclonic Hand Vac Model # V15Z. Where can I get a belt for it.
Shark V1510 Belt is the same model - head to SharkVac.com and you should be able to find them. $7.95 for two plus about $5 shipping.
Jul 03, 2008 | Vacuums
Panasonic MC-E583 Bagged Upright Vacuum Logo
1,987 people viewed this question
Top Panasonic Vacuums Experts
Joseph Hoffmann
Kevin Getz
Kevin Getz
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
