Question about Sony PlayStation Portable (PSP) Console
Psp will not charge or power on - Sony PlayStation Portable (PSP) Console
I suggest u take it to the x-box repair center they repair all consoles
Posted on Oct 02, 2009
I need to know if the power source could be the problem. I already replaced the battery and it worked fine for a week, and then died. I already took it apart once and fixed the dpad, so that's not a p
This could be due to a faulty charging cable, a burnt-out battery or the interference of software you have downloaded. Solve these problems by testing your PSP to locate the charging problem and proceed to implement the correct solution.
Instructions
Revert to Factory Settings
1 Switch the WLAN button on your PSP so that it is in the "Off" position. Remove any memory stick or UMD that is in the system and put them aside.
2 Choose "Settings " from the left side of the cross media bar. Scroll to "Restore Default Settings." Press "X" to enter this menu. Press "X" to accept the restoration. The PSP will then revert back to its original settings.
3 Power off the PSP and plug it into an outlet with the AC adapter to charge for three hours. Power on the system to see if if the charging issue has been resolved.
USB Charging
4 Power on your PSP and scroll to the far left of the cross media bar. Choose "System Settings" and press "X." Scroll down the System Settings menu until you reach the option for "USB Charge." Press "X" and switch the setting to "On."
5 Return to the "System Settings" menu and choose "USB Auto Connect." Make sure the Auto Connect setting has been turned on. This allows your PSP to enter USB mode and begin charging whenever it is connected to another device.
6 Connect the PSP to a powered on PS3 or PC using the USB connector cable. The small end fits into the top of your PSP while the large end is inserted into a USB slot in your chosen system. The PSP will automatically enter USB mode as soon as it is connected.
7 Leave the PSP attached to the system for 30 minutes to an hour. When you detach your PSP, check your battery power. If it has gone up, then the charging problem is with your AC adapter. You can replace it or continue to use the USB charge function.
Battery
8 Plug your PSP into an outlet using the AC adapter cable and power on the system.
9 Enter the "System Settings Menu." Scroll down until you reach "Battery Information." Press "X" to open the menu.
10 Check the last option on the page which is labeled "Battery Status." If the status does not say "Charging," then the battery is not receiving a charge from the cable. While your PSP is getting power from the cable, you will need to purchase a new battery.
Oct 04, 2012 | Video Game Consoles & Games
How would l charge my psp 1001 using my usb. thanks
PSP automatically charge itself when you connect the USB cable from the PSP to your computers USB port you should see the power light change from green to orange that is a sign of a charging state and if that did not happen connect the PSP on a different USB port on your computer because sometimes some USB port supplies less amount of power.
Nov 25, 2010 | Sony PlayStation Portable (PSP) Console
I am not able to start my PSP 3000 I am using a usb cord to charge the PSP, I am getting the hold light however not getting the power on please assist
When you connect the PSP via the USB, does the orange light power on? If you are using the standard USB cable and attached to the top of the PSP, from experience, it needs at least to have a little amount of battery power. If not, it will not totally power on or charge. You need the A/C adapter to charge the battery pack.
I can charge my PSP through USB cable even if its powered off. I'm using this one:
Sep 09, 2009 | Sony PSP-3000 Black Console
Psp dont charge
i think its one of 3 things
1. the internal power connector
2. part abxy and power switch circuit board
3. bad battery
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
Psp won't charge
check the battery or the charging cable is not inserted correctly or its cutted
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp usb charging problem
ok a psp CANNOT in any way shape or form charge by using a usb cord.
so your kidding yourself if you think u got it to charge off of your pc in the first place.
but that is the problem you CANNOT charge your psp via usb
Dec 27, 2008 | Sony PlayStation Portable (PSP) Console
My psp wont charg
If it won't charge and wont power up then same thing happened to me. If you are willing to open up your psp there is a video on youtube that can show you whats wrong. The cable that connects the buttons on the right side most likely disconnected from the main board and the right side of the psp including the buttons, the power switch and the top right trigger won't respond. When you try to turn on the psp and when its charging if the light won't come on then you might have this problem.
May 10, 2008 | Sony PlayStation Portable (PSP) Console
Chargers
no u can nly use the power cord
Mar 22, 2008 | Sony PlayStation Portable (PSP) Console
Charging a PSP
Sounds like it could be the mains/charger of the psp, have u tried using it on the other psp? If that dont work then it may be the power charging unit of the psp itself, u may have to call Sony and have it replaced
Hope it helps
Z33m
Dec 10, 2007 | Sony PlayStation Portable (PSP) Console
Switching on my psp after charging it
Please mention after switching on the PSP power LED turns on or not? ================================================= Suppose without connecting the charger when you power on your PSP you will see green light and you will get sound clear with no display at all and after 1 min: PSP will turn off automatically. then 99% it means that your PSP is bricked.
Aug 01, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
