Washer very louded in spin cycle.
Hello i have a kenmore front loading washer machine it is 4 years old. when it is in spin cycle it sound like it going to take off.. It gets louder and louder can this be fixed..
  • 378 Answers
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer for a quote and then draw your own conclusions as to whether it's worth it.
Posted on Oct 02, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore front loading washer drum is loose and makes loud noise when spinning?
sounds like support springs for the drum have become detached or broken. Do not use, suggest new machine as old ones not worth the investment.
Oct 01, 2012 | Kenmore Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
My washer is very loud when it is in the spin cycle.
if the machine is more than five years old or it gets a lot of use it sounds like the drum bearings are starting to wear. If it sounds like a jet taking off when it begins to spin then thats your problem. Basically bearings have seals which over time and use will eventually allow water in and the bearings will start to wear. Now is the time to get the bearings done before they seize. It can be a laborious and expensive job
May 24, 2010 | Kenmore 43042 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
