Question about NEC ND-3550A DVD±RW Dual Layer Burner
No upper and lower filters visible in registry
My dvd and cd drive are not playing anything. The device driver is empty and When I tried to delete the filters they were not present in the registry. What other step by steps can I take to get them running again. fix it from windows could not fix it, I tried driver agent which tells me it's fine which is wierd. I have a custom built computer with an asus motherboard and the dvd/cd are nec dvd_rw nd3550a nec_dvd_rw-3550 cd rom. If i'm correct they're from pioneer.
  • 251 Answers
Boot your computer into the bios and check to see if the drive shows there , if it does then dissconected the drive ( with power off ) and reboot the computer , let it fully boot , then turn off and reconnect the drive and windows should pick it up
Posted on Oct 23, 2009
Computer will not burn or play disc
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Feb 21, 2012 | BUSlink (DBW1647-FE) DVD RW Dual Layer...
Dvd drive will open but not play anything
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 07, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
My cd / dvd drive will play dvd's but will not play cd's. why?
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 26, 2011 | HP Computers & Internet
My cdrw/dvd drive suddenly stopped burning dics. It will read and play discs but will not burn. I tried to search for an update to the driver but it says i have the most current one.
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 23, 2011 | Philips Computers & Internet
My laptop disc driver is unable to read disc contents. also when we on the laptop dvd drive is not visible on screen . only after restarting it is visible on the screen. Regards anbu
device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps don
Mar 13, 2011 | Computers & Internet
Hi, i have an asus laptop, the cd player wont play anything. its spinning and sounds as though its about to load in but nothing comes up not even an error!! itunes, realplayer or windows wont pull it...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 28, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
THE CD/DVD PLAYER ON MY HP PAVILION a1110n WILL NOT PLAY ANYTHING. IT SOUNDS LIKE IT IS SPINNING BUT, IT MUST NOT BE READING. I TRIED TO UPDATE THE DRIVERS BUT, I STILL CAN'T GET ANYTHING TO WORK. THE...
First of all check if the drivers are properly installed in device manager:-
Right click on Computer and then click Properties--device manager, expand CD/DVD Rom drive and check if the driver is installed.
If driver is installed right click on it and click on delete and then restart the computer.
If the above step doesn't help then try to delete upper/lower filter in registry:-
Click Start--Run type 'regedit' and press enter and now expand the following-
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
now on the right panel right click the 'upper filter' and click delete and then right click the 'lower filter' and then click delete.
If these steps doesn't help then it means there is a hardware fault with your dvd/cd drive and you need to replace the same.
Dec 19, 2010 | HP Pavilion a1110n (PX743AA) PC Desktop
This dvd writer can read and write dvd, cannot read and burn cd
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
or it might be a registry problem you did mention if you could see this dvd burner in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 17, 2010 | LG GH22LP20 DVDRAM Burner
MY COMPUTER IS NOT SHOWING THE CD DRIVER. HOW CAN I EXPLORE THE FILES OF MY CD?
you might have to physically unplug then plug back in this should activate the found new harware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 05, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My Compaq computer shows that the CDDVDW JS-H6532 driver is not working-msg is windows cannot load the device for this hardware. The driver may be corupted or missing code 39. I need to download a free...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 02, 2010 | Compaq Computers & Internet
NEC ND-3550A DVD±RW Dual Layer Burner Logo
1,546 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
