Question about Casio FX-300MS Calculator
I need to reset my scientific calculator so it gves me scientic notation and normal numbers
  • Anonymous Mar 25, 2014
    converting numbers in scientic notation to decimal and vice versa
  • Casio Master
  • 7,993 Answers
Hello
Press the [MODE] key until you reach the display format setup screen, with FIX, SCI and NORM. Under them you have, repectively, 1 2 and 3.
Press the number under the display format you want. If you are presented with 0 tilda 9, you are expected to enter a number between 0 and 9. The number you enter will decide how many decimal digits your results will have.
Hope it helps.
Posted on Oct 11, 2009
  • k24674 Oct 11, 2009
    Read the contents of the screen captures. That may help.
My calculator will give me an answer in scientific notation. How do I change it to decimal form?
To switch out of scientific notation, press SHIFT MODE then select Fix or Norm.
Be aware that the calculator will switch to scientific notation anyway if the magnitude of the answer is too large or too small.
Aug 24, 2014 | Casio FX-115ES Scientific Calculator
HOw to change FSE code on Sharp Advanced D.A.L. EL-531X
To change the FSE code on your SHARP calculator press SETUP and choose 0. FIX means that it shows you all the decimal places. SCI is scientific notation, ENG changes the scientific notation in groups of 3's. NORM1 and NORM2 are your normal number ranges, however norm2 starts from zero and anything negative will be written in scientific notation.
Jun 02, 2014 | Sharp Office Equipment & Supplies
Scientific notation
All calculator use scientific notation if the result is too small or too large. Some, like the Casio FX9750G II, offer you two Normal displays, Norm1 and Norm2 that have different limits when numbers are converted to scientific notations.
Here is how to set one or the other.
In Run>Mat press SHIFT MODE (Setup). Scroll down or up to reach the display line. Press F3 to select Norm1 or Norm2.
Oct 22, 2013 | Casio FX9750GII Graphic Calculator
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
How do I change from having the answers displayed in scientific notation to normal number display?
You can set your display mode to FIX or NORMAL ( 1 or 2) if you have them. However if the result is too small ( less then 0.001) or too large the calculator will use the scientific format. Generally if there are not enough display positions to show your result, the calculator uses scientific notation.
Jul 04, 2011 | Casio FX-260 Calculator
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
How do i take off scientic mode just a regualer:
Press SHIFT [SETUP]. You can select FIX for fixed-decimal or NORM for normal display. For FIX the calculator will prompt for the number of digits. NORM gives you two choices: 1 will display numbers of magnitude less than 10E-2 in scientific notation, 2 won't switch to scientific notation until the magnitude drops below 10E-9.
Sep 21, 2010 | Casio FX-115ES Scientific Calculator
Scientific notation when not wanted.
Unfortunately, you don't. For numbers whose magnitudes differ too greatly from 1, the calculator automatically switches to scientific (or engineering) notation. You can press MODE and change the display settings, but there is no setting that will force the calculator to show this number without an exponent.
Feb 25, 2010 | Texas Instruments TI-83 Plus Calculator
Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Jan 09, 2009 | Texas Instruments TI-30XA Calculator
Scientific notation
press menu, there it says science or something like it
set it on float
Oct 31, 2007 | Texas Instruments TI-83 Plus Calculator
Casio FX-300MS Calculator Logo
315 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
