Question about Off The Wall Heating & Cooling
There's no gas coming into my ng wall heater. the valve is on, can it be the thermocuple valve is stuck closed?
  • 101 Answers
Or Thermocoupler is bad nd needs replaced,
Posted on Oct 02, 2009
Can't get any gas to polit light
Are you getting gas to gas valve? if so then pull supply gas line off the gas valve and look in the end of the gas valve there is a screen in it that catches trash make sure its not stopped up. If clear then pull the pilot supply tube from the valve and press knob if you don't get gas out of valve pilot supply hole the replace valve. if gas is coming out of pilot supply hole the check pilot supply tube some times when heater sets up over summer tube stops up at end of tube has a small orifice you will need to open the hole up with a sewing neddle.
Oct 21, 2014 | Heating & Cooling
Install universal thermocouple in williams heater
You may have a stuck gas valve. I would recommend replacing the gas valve. or have a qualified heating repair technician look at it for about $45. The price of replacing a gas valve by a heating repair company can rang from $300 to $450. The gas valve to a contractor cost $150. Find more heating repair pricing here.
Dec 15, 2012 | Williams 3501922 (NG) Gas Compact Heater
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
My gas heater wont turn off. thermostat is unpluged. Off the wall. Heater stays on. Its like 90 in my house.. Anyone have a clue what problem may be.??
relay points are burnt closed at heater or gas valve is stuck open. if you do not know about gas or electical call a repair man! better that blowing up your house.
Jan 08, 2012 | Heating & Cooling
Pilot lites but goes out when releasing valve
when the pilot light lights up and goes out when you release the valve its because the thermocupler capillary tube will not open the gas valve its a safety devise and is faulty you will have to replace it the thermocoupler
Nov 24, 2011 | Heating & Cooling
Where would I find install instructions for a thermopile (lennox 11450097) to go into a gas earth stove model TG300DV
Hi and welcome to FixYa. I am Kelly
You do not even have to turn off the gas to the stove to change the thermocouple.
It is a matter of unthreading the fitting from the gas valve and routing the new thermocuple in the same matter as the old one. There usually are 2 -3 mounting screws for the thermocouple head. Remove the screws and install the new thermocuple head in the same place as the old one.
Before you screw the new thermocouple into the gas valve make sure the mating area inside the gas valve is clean then thread the thermocouple fitting into the gas valve.
Sometimes the igniter is also mounted on the same bracket as the thermocouple just be careful not to damage it if yours is installed in the same manner.
It should not take more than 20 minutes......
That is it.... simple as that.
Thanks for using FixYa
Kelly
Feb 18, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a propane furance in a mobile home. When I turn the thermostat up the furance comes on a heats the room to the set tempature. after the room cools back down the thermstat clicks but the burner will...
if you are getting power to the gas valve, then all of the safety switches should be closed. if you have any drain lines off of the inducer fan and at the bottom of the heat exchanger, make sure they have a trap and have water in them. the pressure switch may be the culprit.
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
The pilet will not stay lit,when you release button
check for eco switches two wires coming from gas valve at thermocuple hook up this is a flame out saftey
Feb 26, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
62 people viewed this question
Top Off The Wall Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you an Off The Wall Heating and Cooling Expert? Answer questions, earn points and help others
