Question about Sony KP-51WS500 51" Rear Projection Television
Sony 51'' Projection HDTV Turns off after 6 seconds, has 4 blinks
Sony 51'' Projection HDTV KP-51ws500 Turns on, has sound for 6 seconds, and a green arch is in the top of the screen, and the screen is all black. Then shuts off, and blinks 4 times. Anyone have the service manual to this freakin' thing or know what's wrong?
  • 3 Answers
SOURCE: color distortion and arched picture
you have a bad or maybe 2 bad stk392-560 ic's..
and or a bad pico fuse on your g board.. (there are two of them and 6 of them under your ic's
You can check with a vom meter. (resistors) Not ic's need special meter for that
Jason
Tmoore15@indy.rr.com
Posted on Nov 05, 2008
  • 126 Answers
SOURCE: Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Posted on Jul 09, 2009
  • 668 Answers
SOURCE: KP-51WS500 when on it blinked 4 times and has redscreen
Typically if you have a all Red Screen it is caused by either the Red CRT being shorted or The Red CRT Driver Board being bad.
Posted on Jul 18, 2009
roety
  • 585 Answers
SOURCE: sony kp-51ws500 blinks 6 times
Problem on the D board, overvoltage/overcurrent protection circuit, possible part # is A1300417A , Sony also has CRT issues so be prepared to spend between $400-$550 (D board) or $800 (if D and one CRT is NG).
gd lk
Eric
Posted on Aug 18, 2009
SD Tech
  • 14553 Answers
SOURCE: My KP-51WS500 rear projection is showing these
This was one of several Sony models that had bad picture tubes--the set uses a red, green, and blue tube.
There is something easy you can try that may help you get some more life from the set.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SONY SCREEN ADJUSTMENT:
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
If it works you may only be buying some time--if the blue tube caused this it may return at some point.
If all this information has helped you rate this solution as I do this here for free.
Regards, SD TECH
Posted on Dec 20, 2009
Sony KP-51WS500: This TV comes on for a few seconds of picture and sound. Then the picture fades to green and then turns off within another 10 seconds. Is this a power supply problem? Or should I look in...
Adjust the Green screen drive,turn it down and see if that corrects the problem.
Remove the Front Bottom Panel on front of Tv and behind it will be the Screen/Focus Control block
It will have 3 controls on Top for Focus to each Tube R/G/B
and under them are the Screen drive controls for R/G/B.
But if adjusting the Green Screen Drive Control does not Fiox It ,then you have a Bad Green Tube.
Jul 03, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a Sony rear projection tv model KP-51WS500. It has had some fine green lines across the screen, but today it has started to fade to green after being on for a few seconds, then truns off. Any...
It sounds like the focus pack needs to be replaced (p/n 122392535) and re-adjusted. The re-adjusting could be the tricky part if you haven't done these before.
Jan 30, 2011 | Sony KP-51WS500 51" Rear Projection...
I'm getting 6 blinking lights on the dashboard of my Sony KP-51WS500 and no picture
there is a voltage regulator locATED next to the flyback transformer this will fix ur proble normal repai is about $250
Apr 12, 2010 | Sony KP-51WS500 51" Rear Projection...
Jul 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 tv went red screen on me it has 4 blue lines going across also has blinks 6 times.. what do you think this might be..
Off hand I would con dim the Red and Blue CRT"s. If you were to replace two of them I would also do the Green CRT as well. The cost of just doing two of them is way too expensive in my opinion and you would be better served to replace the set instead of investing the amount of money needed in a 6-8 yr. old set.
Hope this helps,
Skyassoc
Jul 15, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp 51ws500 Screen fades to blue
the tuner is going out on it or has gone out and yes its fixable
Aug 29, 2008 | Sony KP-51WS500 51" Rear Projection...
TV turns on then off
the green crt is most likely shorted. thats fairly common with that chassis.
May 04, 2008 | Sony KP-51WS500 51" Rear Projection...
I have the 51" rear projection (kp-51ws520) and problems...
The same problem?? Sounds like a green crt driver is defective or the green crt is bad.
Aug 14, 2006 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
