Question about Samsung SC-D372 Camcorder
The zoom button isn't working and therefore when looking through the lens everything is blurry
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Follow the instructions below to check and test the focusing of the camcorder.
Manual Focus
✤ In the following situations, you may obtain better
results by adjusting the focus manually.
a. A picture containing several objects, some close to the
Camcorder, others further away.
b. A person enveloped in fog or surrounded by snow.
c. Very shiny or glossy surfaces like a car.
d. People or objects moving constantly or quickly
like an athlete or a crowd.
1. Set the [Power] switch to [CAMERA].
2. Set the [Mode] switch to [TAPE] or [CARD].
(SC-D375(H)/D975 only)
3. Press the [Q.MENU] button.
 Quick menu list will appear.
4. Press the up/down arrow button to select <Focus>, then
press the [OK] button.
5. Press the up/down arrow button to select <Manual>, then
6. To exit, press the [Q.MENU] button.
 The [MF] icon and the [MF/AF] status bar will be
displayed on the LCD screen.
7. Press the up/down arrow button to adjust the focus.
[ Note ]
Manual Focus is not available in the EASY.Q mode.
Make sure the lens is clean--use a soft cloth and don't press hard when wiping--use a circular motion starting from the center of the lens and working to the outside--that way, you wont grind dirt into the glass. If the lens is dirty enough, the camera will actually try to focus on the smudge or finger prints on the lens! Look into the lens and use the zoom button--do the interior lenses move forward and backward? The zoom button could be damaged(liquid or impact), or the lens could be jammed due to impact or liquid( I just fixed my sister-in-law's unit--had cola in it and sugar acts like super glue when dry.)(Lenses jam due to excess heat, too) NEVER leave a camcorder in a hot car. The grease used to enable the parts to move freely and smoothly can flow to sensitive areas and stick like glue.
If the focusing is indeed stuck, the unit must be repaired at a reputable facility. Don't send it in through a retail store unless under warranty.--Hope I was of help.---Rick
Posted on Oct 02, 2009
  • Richard C Cohen
    Richard C Cohen Oct 02, 2009
    One more thing, simple too! Facing the rear of the camcorder, on the right side of the viewfinder, sits the focusing button which slides. If that little wonder gets moved the video will be FINE but everything you look at in the viewfinder will be blurry.(the lcd screen should be totally fine also, of course.) The adjustment is for people who wear glasses. They can remove them and still see clearly through the viewfinder only.
I have a Olympus C-750 UltraZoom. I was taking pictures and everything was normal, but then I noticed the viewfinder was blurry. I was walking through a tunnel under a river and I thought the temperature...
Hi Steve, I inform you that the problem only is moisture. Please follow this.
1. Put the camera in sunlight for few hours. After that use it & if you face same problem then
2. You need to visit camera repair shop and they open the camera completely and clean all the inside part of the camera. because you need to clean the moisture inside of lens, viewfinder & sensor too.
So only hope in sunlight. If its solve then fine.
Jan 21, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
Tip
Fix lens that won't extend fully
If your A360 only extends the lens partway when you turn the camera on in picture mode, there is an easy solution that requires no technical knowledge whatsoever. Mine exhibits this behavior most of the time, and I've experimented it with it and found that these two things help:
1. Hold the power button down the entire time the lens is extending. For whatever reason, this seems to help.
2. If your lens extends only partway (if this is the case the screen and all pictures you take should be blurry), simply hit the macro mode button (the little flower to the left of the zoom) twice. This works because when you go into macro mode, the camera automatically brings the lens to its lowest zoom, which is meant to bring the lens back from a high zoom, but also works in reverse. You may have to repeat this procedure a couple times each time you start the camera (you'll know it's fixed when you no longer hear the motor whine when you press the button).
One last tip: if you've had this problem before and you start up your camera and it seems fine, use trick number 2 anyways, just to double check that the lens is indeed in the correct position. I've made the mistake of assuming, based on the fact that the picture on the screen looked sharp, that the lens was fully extended. When you look at your pictures, you may find that all of them (even those taken with a tripod!) may be blurry.
on Aug 03, 2008 | Fuji FinePix A360 Digital Camera
I have a Casio Exilim Zoom EX-Z80 Digital Camera. And my promblem is that once i zoom out everything is blurry. The whole picture is blurry but once I zoom out it is a bit better but not as much. I need...
Try cleaning the lens gently with a lens cloth or maybe a damp paper towel? Other than that - you may have something stuck in your lens that is making everything blurry when you zooom in...or the lens may need to be replaced to be fully functional. Do you notice any blurry spots when you zoom out that get bigger when you zoom in? If so something may be stuck in your lens. Good luck!
Jun 30, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
My camera cant focus on anything
It seems as if the lens isn't installed properly, make sure it's screwed in right in its mount.
Tom
Jun 20, 2009 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
''New'' Lens will not Focus,how can I fix this problem
Try Nikon's website for connection to their Technical Support. www.nikonusa.com
Jun 11, 2009 | Cameras
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Blurry screen
it is most common problem you lens focus is out this could be mechanical or a electronical problem.
Sep 22, 2008 | Canon PowerShot A75 Digital Camera
My Casio EX-600 makes clicking noises when the lens comesout.
Lens error. send into casio repairs and they will fix it for you.
Sep 09, 2007 | Casio Exilim EX-S600 Digital Camera
Samsung SC-D372 Camcorder Logo
187 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
