Question about Motorola Mobility Hint QA30 Cell Phone
The phone turned off on me. I tried to turn it back on but it won't turn on. The backlighting and keys light up, but I can't get it to turn on.
How can I reset my password on my Lg L34c phone
Try this, Take the battery out. Put it back in. Press and hold the following keys at the same time for about 1 to 2 seconds until the touch key backlights turn on: Power/Lock Key and Down Volume Key. As soon as the backlight on the touch keys is turned on, release the keys. Then touch and hold the Home Key until the LG logo is displayed. Your phone will perform the hard reset.
Feb 18, 2015 | LG Cell Phones
Accidentally turned backlight off.
Totally dark? If you have the phone under a light don't you see anything on it?
you may have to take it to someone to get it reset but I'l have to check if we can do that over the internet.
Jun 29, 2008 | Motorola Mobility V170
I have a Aastra Telecom 9316CW Corded Phone and I have lost my manual. I need to know how to turn the light back on in the window. Please, please let me know or tell me how I can find out. Thank you. ...
Do you mean the feature light or the backlight for the display? The feature light can be set to on or off.
To set the light, press Save then 1 (for light on) or zero (light off). Press the desired memory key to associate with the feature and then enter the code from your telephone provider for that feature. Press Save and then label the memory key.
To use the feature light, press the memory key (as selected above) and then lift the handset. Press either Handsfree or Mute. The feature and the light will turn on or off. When the phone is not in use, then Feature On will be seen in the display.
The backlight is not adjustable. You can adjust the contrast with the Contrast button. Backlights do fail over time (but it's not a repair I recommend if the phone is out of warranty).
The manual is available here: http://www.aastratelecom.com/cps/rde/xchg/en-ca/hs.xsl/21564.htm . Look at the bottom of the center section for the PDF.
I hope this helps.
Mar 03, 2011 | Nortel Lands Phones
I would like the keyboard light to stay on - or always come on when I begin to hit the keys...
Go to Options > Screen/Keyboard.
You can adjust the following settings
Backlight Brightness
Backlight Timeout
Automatically Dim BB
Turn on/OFF the auto backlight diming feature
Thanks for using Fixya
proton
Sep 01, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My motorola krzr main screen backlight will not turn on.
Take it back too were every you bought it if you broke it yourself they will not help with you with it, If it just did that automatically you have a possibility too get a bran new one
Jun 24, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Backlight went out
the HTC needs to be reflash to correct this issue...so take the phone to a mobile service center to have that done or try sourcing it online.
Jun 09, 2009 | HTC Touch HD Smartphone
I don't know how to turn the key lights on my enV phone
Go to settings, display settings, backlight, keypad, internal, and change from there. Good luck!
Jan 06, 2009 | LG enV VX9900 Cellular Phone
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Background lighting gone crazy
Ok, this problem is a game glitch, if you downloaded it from the internet, it may have some bugs or some glitches that screws up your phone. I suggest you go back to the shop and exchange a new phone because if it was only three days, the warranty is still valid. So go to the shop immediately.
Aug 20, 2007 | Sony Ericsson K800i Cellular Phone
Motorola Mobility Hint QA30 Cell Phone Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
