Question about Apple Audio Players & Recorders
My ipod touch says it's disconnected and to connect to itunes but it doesn't work how doo i fix it
    President:
  • 267 Answers
HI,
RESET IT
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 02, 2009
I dont know what to do to my Ipod on itunes all it keeps saying is connect to itunes what do i do
Is the Ipod on when you connect it? If so, reset it and connect it again. If that doesn't work, check that the cord you are using isn't broken or your Ipod's jack isn't messed up. If it still doesn't work try a different usb slot on your computer.
Jun 07, 2012 | Apple iPod touch
Tip
How do I update my iPod Touch updated to 3.2
<p>Apple iPod Touch is a touch-screen iPod that contracts with the iPhone and iPod parts. To update the iPod Touch, iPod Touch you have to program a computer running iTunes 3.2. Update the iPod Touch is free and takes only minutes. <br /> <p><br /> <p>1. Connect the iPod Touch to your computer using the USB cable that came with the iPod Touch. <br /> <p><br /> <p>2. Let iTunes opens automatically when the iPod Touch is connected to the computer. <br /> <p><br /> <p>3. Click the name of the iPod on the left side of the screen. If the iPod does not have a name, it will read "iPod". <br /> <p><br /> <p>4. Click "Sync" in the lower right corner of the iTunes program. Disconnect the iPod Touch during the synchronization process. Progress, looking at the status bar at the top of the iTunes program. <br /> <p><br /> <p>5. Disconnect the iPod Touch as the synchronization is complete. You said that the synchronization is complete by reading the status bar at the top of the iTunes program. He will tell you that it is now safe to turn off your iPod Touch. <br />
on Aug 05, 2011 | Computers & Internet
How do i connect my ipod touch to itunes?
Plug in your ipod to the computer, and iTunes should recognize the iPod. If this doesn't work, try a different cable or USB port.
Apr 24, 2011 | Apple iTunes
How do I fix my ipotouch when I forgot my password and it reads ''IPOD IS DISABLED CONNECT TO ITUNES''?
Here you can find instructions for the ipod nano which should also work for ipod touch:
http://support.apple.com/kb/HT1350?viewlocale=en_US
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
Mar 07, 2011 | Apple iPod touch
On my ipod touch, it says that ipod is diasabled and connect to itunes. when i connect my ipod touch to itunes, itunes say that itunes cannot connect to ipod touch because it is locked with a passcode. i...
this is the solution for this kind of issue. please try it. It might work on your ipod touch.
please click here
hope this helps . . . please don't forget to vote for this solution if this works for you :) . . . thanks
Apr 12, 2010 | Apple iPod touch
How can i fix and ipod touch that says ipod is
You'll hv to restore the ipod..here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6
Aug 26, 2009 | Apple iPod touch
How Do I Unlock My Ipod Touch When It Says Its Disabled?
"1. Connect the iPod Touch
2. Press and hold sleep+home until the device reboots.
3. Keep holding until that "please connect me to iTunes"-screen appears
4. iTunes says something about having detected a touch in recovery mode. Allow it to do its thing.
If you get the -18 error, proceed:
6. Close iTunes
7. Reconnect the iPod Touch
8. iTunes launches and shows message as in step 4, but this time, the recovery will work."
Hope this helps!
Aug 15, 2009 | Apple iPod touch
How do u delete pics off your ipod touch 8g
connected with pc and try form it
Jul 23, 2009 | Apple iPod touch
Changed passcode -- ipod touch 8gb
It seems that you will have to restore you ipod touch i'm afraid! So, i hope you have your things backed up.
Ok the steps to take are:
1) Connect the iPod Touch
2) Press and hold sleep+home until the device reboots.
3) Keep holding until that "please connect me to iTunes"-screen appears
4) iTunes says something about having detected a touch in recovery mode. Allow it to do its thing.
5) Disconnect the iPod Touch
6) Close iTunes
7) Reconnect the iPod Touch
8) iTunes launches and shows message as in step 4, but this time, the recovery will work
Hope this helps,
Karlos
Jun 28, 2009 | Apple iPod touch
I ipod is disabled i want to fix it
1) Open iTunes
2) Connect your iPod Touch
3) Hold down the Home and Wake/Sleep buttom for about 20-30 seconds
4) Then it will say " Connect to iTunes" Disconnect your iPod and Connect it again
5) Then it will say "your ipod is in restore mode" some like that and click OK and click restore
in iTunes and it will download the new version and that's it.
Good Luck
By: Conception Zavala
Oct 18, 2008 | Apple iPod touch
22 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
