Question about SanDisk Sansa Clip MP3 Player
Device will not turn on. Is there a reset button
    Problem Solver:
  • 5 Answers
On the side of most mp3 players you will find a small hole that it where you will find the reset button use a small needle to press it but don't press to hard as you can go through the rubber and cause damage use the eye part of the needle it works better
Posted on Oct 02, 2009
My dopo tablet i can not figure how to reset it
follow this steps and fix it. God bless you
Touch the "Power" or "Unlock" button (depending on device) to unlock your device screen.
    • 2
Press the "Power" button to turn the device off.
    • 3
Press the "Power" button to turn your device back on.
2. Factory Reset o 4
Touch Menu, then touch Settings.
o 5
Touch Privacy or Storage, depending on your device.
o 6
Touch "Factory Data Reset." A warning message appears. Touch "Reset" to confirm your choice and reset your device.
Oct 27, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Tip
HAD RESET HP iPAQ rz1700 Series (1710 / 1715
While holding the far left (Mobile Media) and far right (Today) buttons, press in on the reset button (reset hole) on the bottom for about 2-3 seconds. To verify that you have hard reset you device, press the power button. If the device does not turn on then you have successfully hard reset you device. To reactivate the PDA, either connect the device to the AC adapter or press in on the reset button.
on Mar 10, 2010 | Cell Phones
Tip
Reset you TomTom password.
To reset your TomTom device, do the following:
1. Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
2. Remove the SD card
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
4. Turn your device on.
Press the On/off button for at least 5 seconds.
5. Insert the SD card
If your device uses an SD card, insert the SD card.
on Feb 07, 2010 | GPS
I bought used touch diamond recently. But, the phone unable to to turn on Wi Fi after a few days even I tried to turn on through "Comm Manger" -> "Wi-Fi". Is the Wi-Fi device issue?
Try resetting your device to factory settings, but before doing so, please take a backup of everything (contacts, messages, calender etc.)To reset the device:
1. Turn off the phone and pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
"This operation will delete all your personal data, and reset all your settings...."
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
It might take a while to start the phone and check the WiFi after the phone has restarted. In case it still has the same issue, then it might be a hardware fault.
May 09, 2010 | HTC Touch Diamond Smartphone
Wonr turn on
Hello :
I recommend you to reset your GPS to solve this problem .
To reset your GPS , try this please :
1:Charge your TomTom for at least 2 hours to avoid any issues upon resetting.
2:Locate the "Power" button at the top right of the device. The Power button is on the top right-hand corner of each device, just as the one shown in the picture.
3:Hold down the "Power" button until the device resets. TomTom warns that this reset process can take more than 15 seconds to complete.
4:Release the "Power" button once the device resets. Your unit is now reset.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Tomtom ONE 130S Car GPS Receiver
I can't get my tomtom to turn on. It is plugged
Straight from the TomTom website:
    I hope this helps!
Mar 09, 2010 | Tomtom ONE XL GPS
Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Do a RESET:
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
My tomtom720 wont reset. help
  6. The reset hole is located on the bottom of the GPS depending on model.
Jul 25, 2009 | Tomtom GO 700 GPS Receiver
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
  2. Locate the small circle with a dot inside (very small)
  1. Lift the antenna
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
Device.exe error
pls hard reset ur device see if it helps otherwise update ur ROM from www.htc.com i hope it helps and pls rate me FIXYA
To perform a hard reset
1. Pull out the stylus.
Mar 19, 2009 | HTC Touch Diamond Smartphone
SanDisk Sansa Clip MP3 Player Logo
187 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
