Question about Honda Water Pump Honda Engine
I need to take the 2" water pump off of my Honda engine. What is the proper procedure? I have the volute cover off, but I can not tell how the volute comes off the engine shaft. I need the engine for an air compressor and I need to get the pump off. The engine has been sitting around for awhile and it has rusted a bit. I would sure appreciate any help. Ron, Klawock, Alaska
  • placeron Oct 02, 2009
    How do I do that
    I can't find a link to post pics.
    Thanks for the reply by the way.
    I just took a few pictures of the pump,
    As near as I can tell, the impeller is threaded on to the engine shaft.
    That is my best guess.
    I am trying to use the engine on a dive compressor that I am setting up.
    I need it done this weekend, but I do have a back up if this one doesn't work out.
    Thanks, Ron
  • Kimbo too May 11, 2010
    can you send some pics Ron?
  • 11 Answers
SOURCE: 2000 Honda Accord's Timing Belt and Water Pump
sounds like your timing belt is a little to tight and the vibration from the belt is the humming you here
loosen the belt but you may want to call the dealer for the spics on tightness of the belt . thx
Posted on Dec 07, 2008
SOURCE: i need 2 know how much engine oil i need for my honda cr125.
If it doesn't have a dipstick or a sight glass window on the kick starter side you will find a srew / bolt on the case usually lower front right near the rear foot brake unsrew that then put your oil in the filler hole when oil comes out of the hole you took the screw/bolt out of you are full I have an 01 and thats the way it is or 650cm of oil
Posted on Apr 21, 2009
  • 3567 Answers
SOURCE: 1988 honda cr125 water pump shaft leak
Go to the site below and download a free service manual for your bike. The manual will really help you, and it is faster than my one finger keystrokes.
http://www.carlsalter.com/motorcycle-manuals.asp
Posted on Apr 27, 2009
  • 98 Answers
SOURCE: honda 5.5 GX160 ran then wouldnt start again
could be a bad coil or plug
Posted on Jul 21, 2009
keithheavili
  • 410 Answers
SOURCE: 2006 Honda Accord Rotor removal.
I've been working on Honda's like this for years, including my own, and there are two ways that you can get the screw out. The easiest/best way to do it is with an impact driver and the biggest phillips screwdriver bit you can find (sorry can't remember the number, I think #4 but not sure). Once you have the bit you are good to go and your impact wrench will do the work for you. If you don't have an impact wrench the other way I've learned to do it is by taking a small (12" section) of rebar and a mini sledge hammer and put the rebar directly on the screw (make sure it is straight) and hit it with the hammer. Make sure you hit the rebar and not the car or yourself. You are probably going to have to hit this really hard to break it loose (you can try penetrating oil, not WD-40, along with this method). After you beat the screws for a while, you are going to need the biggest phillps screwdrive you can find, again not sure what size, and you will be able to get this out. If you have started to strip the screws you need to be very careful and if you aren't sure you can get them out without stripping them I might take it to a mechanic and have them loosen them up for you. Let me know if you have any further questions. Thanks for using FixYa!
Posted on Aug 02, 2009
I have a leak from the bottom of the pump
Also, check for the actual mechanical shaft seal, they leak, and appears as if it's coming off of the wet end. Making it look like the drain plug could be leaking, or the area between the volute which is the pump housing, and the cover, this would normally be a failed gasket or O-ring, depending on the brand. Sometimes just tightening the cover to the pump housing correct this issue.
Jun 08, 2015 | Pool & Spa
Change the water pump
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
Aug 29, 2011 | 2006 Pontiac Solstice
Need R&R information to replace for waterpump Geo Storm 1993 4 cyl
Hi!!
Here is the Info you requested:
WATER PUMP REMOVAL & INSTALLATION
Except Twincam Engines See Figures 1 and 2
  • Disconnect the negative battery cable and drain the cooling system.
  • Loosen the power steering pump adjustment bolts and remove the drive belt.
  • Remove the timing belt; refer to the procedure later in this section.
  • Remove the tension pulley and spring.
  • Remove the water pump mounting bolts, water pump and gasket. Clean the mounting surfaces of all remaining gasket material.
  • To install, reverse the removal procedures. Tighten the water pump bolts to 17 ft. lbs. (23 Nm) and the tension pulley to 30 ft. lbs. (40 Nm).
  • Connect the negative battery cable and fill the cooling system, then start the engine and check for leaks.
Twincam Engines See Figure 3
1.6L DOHC ENGINE
  • Support the engine using a suitable floor jack and remove the right front engine mount.
  • Remove the engine mount bridge and the upper timing belt cover.
  • Remove the power steering belt and the lower timing belt cover.
  • Loosen the timing belt tension pulley and remove the timing belt.
  • Remove the power steering pump and bracket.
  • Remove the water pump attaching bolts, then the water pump from the vehicle. Thoroughly clean all remaining gasket material from the mating surfaces.
  • Reverse procedure to install and tighten the water pump bolts to 17 ft. lbs. (24 Nm). Connect the negative battery cable and refill the cooling system. Start the engine and check for leaks.
1.8L ENGINE
  • Disconnect the negative battery cable and drain the engine cooling system.
  • Remove the timing belt covers; refer to the procedure later in this section. Loosen the timing belt tensioner pulley bolt, then remove the belt from the water pump pulley.
  • Remove the 2 bolts from the power steering pump bracket, then position the pump aside with the lines still attached. Be careful not to kink or damage the steering fluid lines.
  • Remove the water pump mounting bolts, then remove the pump from the engine. Thoroughly clean the gasket mating surfaces of all remaining gasket material.
To install:
  • Install the water pump using a new gasket, then tighten the retaining bolts to 18 ft. lbs. (24 Nm).
  • Position the power steering pump assembly, then install the retaining bolts and tighten to 25 ft. lbs. (34 Nm).
  • Install the timing belt to the pump pulley, then tighten the tensioner pulley bolt to 30 ft. lbs. (40 Nm).
  • Install the timing belt covers.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 11, 2011 | Geo Storm Cars & Trucks
How do i change the water pump belt on a 2001 Cadillac Deville .
2001 Cadillac Deville 4.6L SFI DOHC 8cyl Removal & Installation procedure...
1. Before servicing the vehicle, refer to the Precautions section.
2. Drain the coolant.
3. Remove or disconnect the following:
Negative battery cable
Upper fill panel, if equipped
AIR injection control valve, if equipped
Air cleaner
Oil level indicator tube nut, if necessary
Water pump belt cover
Water pump drive belt
Lower radiator hose
Thermostat bypass hose from the coolant inlet housing
Water pump cover
4. Remove the water pump by rotating it clockwise using special Tool J 38816-1A (water pump remover/installer).
To install:
1. Install the water pump with a new O-ring, by turning it counterclockwise using the special tool, until it stops. Torque the water pump to 73 ft. lbs. (100 Nm).
Fig. To ensure proper operation, be sure to install a new O-ring (click for zoom)
2. Install or connect the following:
Water pump cover. Torque the bolts to 89 inch lbs. (10 Nm).
Lower radiator hose
Thermostat bypass hose to the coolant inlet housing
Air cleaner
3. Refill and bleed the cooling system.
4. Run the engine and check for leaks.
Hope this helps (remember to rate this comments)
Mar 10, 2011 | 2001 Cadillac DeVille
My kitchenaid fills with water just fine and drains just fine; however when I run it it makes this horrible buzzing/grinding sound. Could it be the food grinder or the pump? How do I clear the grinder to...
You need to remove the lower spray arm, then the water volute that runs up the back needs to get disconnected by removing it from its rear clip (center of tub almost behind upper rack, next twist volute connector clockwise until you can pull the connector and upper supply volute tube apart. Remove connector from top of pump and then remove 5? torx screws to remove top of pump (filter plate) then look inside front section of pump sump area and locate two more torx screws to remove (on right) first sump inlet cover. The screw on the left is for the macerator (grinder assembly) cover. Pull straight up on the cover to expose the chopper assembly. Try not to disturb the chopper screen from it's location as it connects to the pump impellar shaft and is difficult to re-install. Clean any and all debris from the now open areas and re- assemble the pump.
Jun 12, 2010 | KitchenAid KUDR01TJ Dishwasher
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
How to remove water pump form honda civic 1994 ex
Hi:
The water pump is located underneath the timing belt cover, on the drivers side of the engine. To swap the water pump, you need to remove the timing belt cover, timing belt, and the timing belt tensioner. I usually tell people that this can be done in a day, but sometimes not ! Also, all of the other drive belts , such as Air conditioning and the alternator belt all need removed too.
Apr 27, 2010 | 1994 Honda Civic
Water pump is leaking, can i just replace seal on a honda cbr 400 rr 1988 model.
Not really!
The leaking (weep-hole) is purposely put in the water-pump to warn you that the water pump is defective.
You have to replace the water-pump together with new gasket.
1. Drain the coolant into a container by opening the radiator cap, and the drain-plug under it.
2. Remove the water-pump hose and the bolts .
3. Put in place the new water-pump with new gasket.
4. Reverse removal procedure for installation.
5. Start engine and check for leaks.
Nov 17, 2009 | 1988 Honda CBR 400
REMOVAL OF WATER PUMP ON 95 MERCURY VILLAGER
go here too http://autos.groups.yahoo.com/group/villagerquest/ Section 03-01: Engine 1996 Villager Workshop Manual IN-VEHICLE SERVICE -------------------------------------------------------------------------------- Water Pump Removal Water Pump Removal Drain the cooling system. Refer to Section 03-03 for the procedure. Disconnect the battery ground cable (14301). Remove the generator drive belt, water pump and power steering pump drive belt, and the A/C compressor drive belt (if equipped). Refer to Section 03-05 for the removal procedures. Raise and support the vehicle. Use Strap Wrench D85L-6000-A or equivalent to hold the water pump pulley (8509) while removing the four water pump pulley bolts. Remove the water pump pulley from the water pump (8501). Remove the crankshaft pulley (6312). Refer to the procedure in this section. Remove the five lower engine front cover bolts and the lower engine front cover (6019). NOTE: Make a note of the location of the one water pump stud/bolt for ease of installation. Remove the six water pump bolts. Remove the water pump. Installation NOTE: Ensure the mating surfaces between the water pump and the cylinder block (6010) are cleaned of any sealant material. Install a continuous 2.0-3.0mm (0.079-0.118 inch) wide bead of Gasket Maker E2AZ-19562-B or equivalent meeting Ford specification WSK-M2G348-A5, on the water pump and position the water pump on the cylinder block. NOTE: Refer to the note made during removal for the location of the stud/bolt. Install the six water pump bolts. Tighten the water pump bolts to 16-21 Nm (12-15 lb-ft). Position the water pump pulley on the water pump and install the four water pump pulley bolts. Use Strap Wrench D85L-6000-A or equivalent to hold the water pump pulley, and tighten the four water pump pulley bolts to 16-21 Nm (12-15 lb-ft). Install the lower engine front cover and the five lower engine front cover bolts. Tighten the five lower engine front cover bolts to 3-5 Nm (27-44 lb-in). Install the crankshaft pulley. Refer to the procedure in this section. Lower the vehicle. Install and adjust the generator drive belt, water pump and power steering pump drive belt, and the A/C compressor drive belt (if equipped). Refer to Section 03-05 for the installation and adjustment procedures. Connect the battery ground cable. Fill the cooling system. Refer to Section 03-03 for the procedure. Start the engine (6007) and check for leaks.
Jun 06, 2009 | 1995 Mercury Villager
Open Questions:
See all Honda Water Pump Honda Engine Questions
Honda Water Pump  Honda Engine Logo
90 people viewed this question
Top Honda Tools & Hardware - Others Experts
gbob59
John Loiselle
Level 1 Expert
Bill Boyd
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
