Question about Maytag Legacy Series Top Load Washer
Washer walking across the floor in spin cylce
The machine in question is 2/1/2 years old. We have re balance it many times. It has started to 'walk' across the floor in spin cycle. Is there a way to permanently stop this from happening?
  • 1 more comment
  • Bobbie123 Feb 10, 2008
    We bought our Maytag legacy series machine in 2005. The machine vibrates and walks so violently that it has taken the plaster off the walls and knocked items off the wall in the room w/adjouring wall. I had Maytag out several times they said it was because I had a sub floor and it needed to be reinforced. I bought an extension to my warranty contract because I had this ongoing problem. But when I kept calling them on it, they said that they would start charging me for the service call because it was on the same problem and they felt it was the floors fault. Well, we opened the floor up, reinforced it with 2X4 cross bracing, put new plywood flooring in, then put cement backerboard on top of that, then tile flooring. It stills vibrates and walks all over my new floor. I feel, and I told Maytag that when we first could not solve the problem, that it is the fault of their machine. Sooo I guess we will just keep using it until it shakes itself to death, which hopefully will be very soon. Then we will buy another - NOT a Maytag!!!
  • Anonymous Mar 15, 2014
    candy gow485 walking across floor
  • Anonymous Mar 28, 2014
    I have tried to balance the machine several times but it stills walks across the room, and today it starting to leak from the bottom. It's only happen once, but I don't dare to use it. I can't get the front panel off to see where the leak is coming from. All hoses and drain line are not wet. What to do I do?
  • 196 Answers
This machine uses an auto-adjust for the back portion and they tend to get stuck. Since it sits on a common chassis, insert two standard legs in the back. There are threaded holes that the legs go in. Rebalance the machine. Your problem should stop.
Posted on Jan 15, 2008
My legacy did the same thing, My floor joists under the machine are 2x12s 16 inch on center, Sounds like a common excuse given to a poor machine design.
In the old days you could the Maytag brand to the Bank, good QA/QC, durable etc today however it seems that you can only take MAYTAG brands to the Dump( or recycling center). I am still trying to decide today if I want to repair this aggrevation or buy something else.
I hope Maytag does not infect the WHIRPOOL brands!
I would not take a free Maytag appliance today if offered!
Posted on Jun 04, 2008
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Washer walks on spin cycle, leveled unit and put carpet under it and it still walks on spin cycle only. I have had this washer for 7 years, just started recently doing this.
This is a sign of machine out of balance. If it has been OK for some time, until now, I would look at the balance springs (usually three of four holding to bowl to the outside of the machine, and see if one has come off, or is rusted through. Either fix or replace.
Does the machine spin just fine with no washing in?
Jan 13, 2010 | Maytag PAV2300 Top Load Washer
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Maytag Washer MDE7400AYW goes off balance while spinning about half the time. Walks across room. Springs are OK. Tub seems very easy to move from side to side by hand.
Typically when the drum spins and walks the washer, it is a loading issue.
As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load.
THis is especially prevalent in loads that are:
1. small,
2. contain lots of towels and
3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
Nov 07, 2008 | Maytag Washing Machines
Timing is off
timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Jul 08, 2008 | GE WSXH208A Front Load Washer
Washer tub goes off balance every time and washer walks!
there may be a possibility here of the centre hub being worn or the liner tub bearing being worn due to the age of the machine.. here is a list and diagrams of the parts you may need and can get from here:-
try to check for slackness when the tub is empty causing a rocking/slapping motion whilst empty. if the tub is used regularly and to its maximum capacity then the likeliehood is these bearings/hubs may need to be replaced.. the "walking" across the floor will be accented by the amount of items plus water in the tub. and if the tub is off balance,then this will be more highlighted when also full of water and items... if you feel this is over the top,then try to lighten the load that is in the tub at any given time. this will determine weather the bearing has indeed worn .the lighter the load,the less "walking the machine should do in cycle.. the only time walking would be unchanged is during the spin cycle,when the speed is of a constant one and it will vibrate at the same rate. placing it on a rubber mat is not a solution but just something that will make you hopefully think it is solved
and you may as well just bolt the machine to the floor and hope for the best
Mar 31, 2008 | Maytag MAT13MN Top Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
218 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
