Question about Canon PowerShot A550 Digital Camera
Blinking flash icon when I try to take a picture
I have a Canon Powershot A630 and sometimes when I try to take a picture on M mode with flash, the flash icon blinks when I press the shutter down, and it won't take a picture. Does anyone know what's going on?
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A630 problem
The LCD screen may be overtaxing your batteries, resulting in shutdown. Are you using alkaline batteries, or worse yet "super heavy duty" batteries? If so, some brands of regular batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Performance varies by brand and shelf life of the batteries (how long were they on the store shelf before you bought them? Their expiration date may be listed on the package.).
Digital cameras for the most part should only be used with rechargeable NiMH batteries. Many retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on May 17, 2008
Fwayne
  • 97 Answers
SOURCE: Canon Powershot A630 can't download pictures
When you plug the camera in and turn it on do you hear the computer make a sound? If so open My Computer and look for a new drive letter or a camera Icon. If present open that and browse the folders there. If you see your pictures you can simply copy them to My Pictures.
If no sound and no Icon, you may need to reload the drivers. Get the drivers and a manual free downloaded from here
Posted on Jan 04, 2009
SOURCE: canon powershot a630 lens is stuck
My lens was stuck inside the camera and would not come out when I turned the camera on. I could hear a sound but nothing was happening with the lens. I used a dental pick (small sharp pointed object) to pull at the lens and it came out and seems to be working fine. Just tried it a couple of hours ago and It seems to be OK.
Posted on Feb 21, 2009
t00nz
  • 4738 Answers
SOURCE: Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Posted on Jun 20, 2009
SOURCE: Canon powershot A630 blinking flash graphic
You have to unscrew the left side of the camera (if you're looking at the back of the camera, the side that is right beside the flash). Then, at the very top, with a tiny screw driver, just gently tap the black flash compartment and it should work after that. I've had the flash problem twice in the past year and both times I got it to work again by taping on it. Hope it helps!
Posted on Jun 29, 2009
I have a canon powershot a630. It suddenly won't take pictures in auto mode. Orange light in front stays lit and arrow on display screen flashes. It will take pics in some other modes (P, Tv, Av,...
See this blog article. If you don't notice any gaps, and tightening all the loose screws doesn't help, then the next likely problem is the flash unit itself is burned out. If so, this would require professional repair to correct.
Dec 30, 2010 | Canon PowerShot A630 Digital Camera
My powershot A630 will not take a picture. When I press the button a lightning bolt appears? Any idea what is up?
The lightning bolt indicates that the scene needs flash. Turn on the flast and try again or try taking picture in P, Av, Tv or M modes.
Dec 22, 2009 | Canon Cameras
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Pictures too Dark
Try resetting the camera. Go into the setup menu and find "reset".
Sep 21, 2009 | Canon PowerShot A630 Digital Camera
Canon Powershot A630 - dark image in auto mode
Could it have something to do with "white balance"? http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=14108#SupportDetailAct
When the shooting mode is set to (Auto), the white balance will be applied automatically. However, with the (Auto) mode, the camera may not reproduce the natural color of the subject.
If this don't help, try their website and see if you can troubleshoot it. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=14108#SupportDetailAct
If all fails, buy a newer Canon Powershot. I've tried the newer models and they seem good.
Jun 01, 2009 | Canon PowerShot A630 Digital Camera
Jan 04, 2009 | Canon PowerShot A630 Digital Camera
Nov 06, 2008 | Canon PowerShot A630 Digital Camera
No flash in auto mode
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON). However you mention the flash works sometimes, so a totally burned out flash tube is unlikely.
It's more likely to be only a break or bad connection in the safety circuit. Many Canon cameras use some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, tighten loose screws and try moving and replacing any missing screws with one of the others that are still there.
May 19, 2008 | Canon PowerShot A630 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Canon PowerShot A550 Digital Camera Logo
246 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
