Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
My brushes wont spin and i dont know why - Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
  • 701 Answers
Your belt has broken and therefore the brush isn't spinning. You can find any vacuum belt at www.vacbelts.com.
Posted on Oct 10, 2009
  • 101 Answers
Belt has probably broken
Posted on Oct 02, 2009
Hi i have a hoover F5853 when the brushes in contact with the carpet they quit spinning but it is on and lift the front up they start spinning but as soon and i put it back down they quit please help
Belt around brush roller is worn, it spins freely when there is no pressure on it. But put it on the floor, the belt won't turn the brushes. I suggest taking unit to vac repair shop for new belt installation
Dec 05, 2014 | Hoover Vacuums
Hoover steam vac the brushes dont spin
It could be one or more different things. The brush assembly might have an obstruction. The shaft coming out of the brush assembly might have broken. It could be a clogged screen or filter. It could be the turbine is not working properly.
Feb 23, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
I cut all of the hair out of the bottom of the spin-brush on the Dyson Upright Animal Vacuum. Now I dont think I can get the brush back in there correctly. If I squeeze it in there (which it is a VERY...
Check the roller ends for dirt build up, they pull off and you should be able to clean them out. The roller should just go back into place if pushed together.
Oct 04, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
I replaced the belt on my bissell model number 3576-2, but when i put it back together, the brushes wont move...the belt tries to move, but the rubber just burns..
something is binding ... i dont know what ... you will have to remove all parts and reinstall again. Make sure the bearings spin on the brush when it is out ... remove all hair and string.
good luck ... im sure it is someething simple.
Nov 10, 2009 | Bissell 6595 Lift Off Bagless Upright...
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
Brushes wont turn
Remove the brush block, turn the unit on its side and watch the square hole to see if it rotates. If not, then the turbine(#23) isn't working, if it is, then is the shaft on top of the brush block broke off, if it is, replace the brush block.
Jul 01, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
190 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
