Kenmore 417 xxxxx front load washing machine. pump seems to be working, but motor just isn't turning the belt. I figure it's either the motor or the motor control board. how do i tell which one?
    President:
  • 744 Answers
Hello, remove the panel below the door by removing the 3 screws under the lower lip. inside this panel you will find the tech sheet which will tell you how to run the diagnostic cycle. This in turn will tell you what is wrong with your washer. If you have any other questions please feel free to comment again. Good Luck!! Mike
Posted on Oct 02, 2009
Kenmore front loading spin noise small vibration
It is probably the bearings on the rear of the wash tub. There have been multiple issues with the bearings. Try rplacing the bearings and the drive belt. I also have a 417 that I've had for almost 10 years.. I've not have a problem yet but it is slightly louder on spinning than it was when it was new. I did some research and found out about the bearings.
Dec 15, 2009 | Kenmore Washing Machines
I have a model 417 front load washing machine.
A long wire flexible brush will work well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 02, 2009 | Kenmore Washing Machines
417 430 42200 Front load Kenmore washing machine The water does not drain
Sounds like the pump is clogged or not working. Check the pump on the bottom of the machine. You can see the pump by removing the back panel for access. If you have missing socks or other small items check for a blockage in the pump.
If you set the dryer to spin you should hear the pump groaning if it is blocked.
Jun 06, 2009 | Kenmore 22422 Top Load Washer
Possible purchase
Hi. from my research, these machines will have issues that are frequent that deal with the drainage system and motor control as well. the control boards are average in their respective categories but, overall, these units will preform well during the short life span.
May 13, 2009 | Kenmore Washing Machines
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore top loading washer stopped working in the middle cycle.
you need to take it some place where you can lay it on it's back and look for this part at www.repairclinic.com/SSPartDetail.aspx?s=b6i1195967&PartID=1195967 This part probably broke and needs replaced. I just did one today. If you'd like call me at 417 926 0106 and I could probably walk you through it. My name is Jim. Or call 417 252 3867
Apr 03, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Front loading washer sears 417---- does not spin
check belt,it is behind machine under back cover.
Feb 17, 2009 | Kenmore 43142 Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Oct 10, 2008 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
